Quad 2-Input NAND Gate
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr 11/23/2015 at 07:473 Comments
The first NAND module has passed testing:
A screencap of the schematic of one of the gates (1/4 of the module):
As you can see, it is basically my standard complementary-driven totem pole output, with a couple of schottky diodes in a wired-AND input configuration.
Almost ready to start populating the stack address decoder panels....!
Andrew Starr wrote 11/23/2015 at 19:39 point
For a stack address decoder:
6 x FF
6 x quad AND
4 x quad NAND
4 x quad OR
4 x 2-to4 decoders
OR modules are in production...
Yann Guidon / YGDES wrote 11/23/2015 at 20:35 point
I can't wait to see them all work together !
Yann Guidon / YGDES wrote 11/23/2015 at 13:33 point
how many of these modules will you need ? :-)
