MiniWear Simblee BLE Module
A project log for MiniWear - DIY Miniature & Wearable Electronics
Creating an open source platform for easily creating miniature and wearable electronics projects
james-cannanJames Cannan 01/15/2016 at 21:590 Comments
I have just created another BLE MiniWear module called the MiniWear Simblee. It is an upgraded ble module that uses a IC that is half the size of the RFduino IC i was using, and has a lot of better features. This module is part of my Tiny Low Cost BLE Project so i apologise for double posting if you have already seen this.
Here is the Simblee being tested with the Blink Sketch
The Eagle design files have now been uploaded to Github
If you are interested, here are some Simblee specs copied from their website:
In practice, i only breakout 3 of the simblee pins, as MiniWear is designed to work with the I2C communication protocol.
