Arduino Pro Mini - 8x8 DIY matrix
A project log for LED displays on Arduinos - a collection
for building clocks and bring them anywhere you want, even integrated a temperature sensor, if you're into that kind of stuff
davedarkodavedarko 10/04/2016 at 15:079 Comments
[Update] hand soldered board
This one is almost as big as the small 20mm x 20mm, inspired by @al1 's visit at my place, showing of his colourful and tiny RGB displays. I plan on putting this on arduinos and just run and hope for the best with blue or white LEDs.
don't be cheap, use fresh solder paste :D first heatgun station (858D) clone test.
I needed something to calm down my nerves - the annoying colleague was annoying - so I hand soldered the board with the today arrived UV LEDs. I wanted purple leds on a purple board...
Alex wrote 10/25/2016 at 20:02 point
Are these 0805 LEDs?
davedarko wrote 10/25/2016 at 20:07 point
0603s
davedarko wrote 10/25/2016 at 15:19 point
Boom. Happy.
Alex wrote 10/25/2016 at 15:51 point
nice
ajlitt wrote 10/23/2016 at 19:37 point
yech.  I'll do a test run next time I do reflow...
Eric Hertz wrote 10/23/2016 at 14:48 point
ah hah! If that's what happens with old solder-paste, then no wonder I've always had so much trouble with it I thought it amazing anyone could use it. Musta got some old-stock... 'cause that's basically exactly what my experience has been... but not nearly to such a scale ;)
deʃhipu wrote 10/23/2016 at 12:59 point
What am I looking at? What happened there?
davedarko wrote 10/23/2016 at 14:06 point
Just old solderpaste and flying LEDs...
Alex wrote 10/04/2016 at 15:39 point
nice!
