PCBs Ordered
A project log for uPre
An preamp for electric instruments, based on an Opamp. (pronounced Micro-Pre)
avrAVR 09/30/2016 at 17:490 Comments
So I cashed in on a OSHPark giftcard I had laying around (thanks little bro) and ordered a PCB for the new uPre! This will serve as a good test build of the new design with PCB mounted potentiometers. It will be good for testing the circuit and how well it performs. The next version depending on the how this one works out will be redesigned to better fit inside instruments and enclosures.
OSHPark Board Render:
Next post should be on assembly and testing, can't wait to get PCBs in the mail :)
