New Firmware: USBasp
A project log for AVeRCADE
Customisable USB adapter for arcade controls.
danjovicdanjovic 02/06/2016 at 02:330 Comments
I have modified USBasp code to run on AVeRCADE. Basically I have did 3 things:
The connections to ISP and LEDs can be seen below. The jumper is optional since AVRDude allows to use the -B option to perform programming at low speed.
The prototype can be seen below.
