Pointduino Mini
Very tiny Arduino compatible board
This is one of the simplest Arduino compatible board. In a 18mm x 18mm sized board, it has only Atmega328 chip on the top side of the pcb while other side consists of 8 mHz crystal and AMS1117 voltage regualtor as well as with some capacitors and a resistor.
  • 1 × Atmega328 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × AMS1117 (3.3v regulator)
  • 1 × 8 mHz Crystal
  • 2 × 22pF Capacitor
  • 2 × 1 uF Capacitor
View all 7 components
alpha_ninja wrote 12/07/2015 at 00:51 point
I can't find your design files, could you link to them?
alpha_ninja wrote 12/02/2015 at 00:46 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
deʃhipu wrote 11/08/2015 at 13:06 point
I love it. One could solder two rows of the pins on one side, and two on the other, still making it breadboard-compatible.
zakqwy wrote 10/08/2015 at 15:42 point
