Enclosure
A project log for Pi Media Station: Dual Pi Media player
A Reworking of my Pi Video Player for a static installation
craig-hissettCraig Hissett 10/09/2015 at 13:252 Comments
I will post a sketch of what I am planning very soon:
Front Panel
Touch screen, with 4 buttons underneath for triggering underneath. Size of buttons TBC
Side Panels
Slots to hold an internal shelf, i2C and USB breakouts?
Bottom side
Holes for rubber feet to be screwed into
Back side
Power in, USB ports of Pi/s exposed for connection?
Inner shelf
For mounting Pis to.
The Enclosure could bear a resemblance to this great build; just change the disck drive on the front for some buttons and lose the keyboard/mouse :)
Craig Hissett wrote 10/12/2015 at 17:08 point
I have slightly amended my design to make it a bit better aesthetically; the front panel will be flat rather than sloped.
Need to work out dimensions soon:
The Screen will be the same screen used in v1, so I have the dimensions of that; same with the arcade buttons that will go under it.
The two Pi's dimensions are easily attainable online.
Housing these components will give me a good estimation of what the sizes need to be; some space will be taken into consideration for cable management too!
Craig Hissett wrote 10/09/2015 at 23:58 point
I am delight to welcome Alex Rich on board with this project!
Alex was the driving force behind version one. If Alex hadnt created the enclosure for v1 i very much doubt that this project would have ever got of the ground.
Cant wait to see what Alex can do for for version two!!
