Maintenance the LEDs.
A project log for Wide-Gamut monitor with 5050 RGB LED mod.
Increase the Color Gamut, Primary color purity and make stunning vivid and accurate LCD monitor with RGB LEDs. Inspired from Dolby PRM-4220.
thomas-chanon-wangtriratThomas Chanon Wangtrirat 05/01/2016 at 03:350 Comments
Sometime huge array of LED that has been assembled by hand, sure that it will have fault by heat or loose connections sometime. So I maintaining it after being use as Mastering monitor for 5 months.
