BMS Logging Completed
A project log for goMon
Govecs Electric Scooter Remote Monitoring
nuno-cruzNuno Cruz 11/12/2015 at 23:171 Comment
Just finished building the BMS logger part, I'm able to get everything from the BMS which as a serial port for a PIC controller that is responsible for the management of the two OZ890. Reverse engineering the bms proved to by harder than I thought, almost two months building the code for arduino.
Sérgio Madaleno wrote 12/04/2023 at 19:03 point
Could you share more info?
