Schematics and more details
A project log for goMon
Govecs Electric Scooter Remote Monitoring
nuno-cruzNuno Cruz 11/24/2015 at 21:270 Comments
Here's the main schematic of what I'm trying to build, with the compromises of not having some of the modules available at fritzing. For example as screen, I'm using an itead nextion HMI display, which rocks! And as internet connectivity I'm expecting to use either a 3G module (cheaper sim800l solution) or a YUN shield. The yun shield has the advantage of allowing to build some sort of script on the linux side that could switch between a 3g and a WiFi connection (with the added support of 802.1x, needed for the wifi network at work). The RFM23BP works when parked at home to allow the monitoring device to connect to my house. So yes, at my house I'm also having another RFM23BP, but connected to an NodeMCU, since at home I don't need the 802.1x support. The RFM23BP will be an added feature, if 3G is unavailable at all times, or if I don't want to pay for a 3G data plan on a card to be used only for monitoring.
