All I did here was connect RCA jacks to the amps on the board that connects to the neck of the CRT. Composite video goes to the composite video input for sync. That's about it!
If you do this yourself, just be aware that touching something in there that you shouldn't could give you a pretty good shock, or potentially kill you. So there. You have been warned.
