Transmission Troubles/Floor Failures
A project log for Electric Sonett: Old Car/New Tech
This project focuses on ecological sustainability and social responsibility through reuse. Increasing lifecycle efficiency, decreasing cost.
adam-curtisAdam Curtis 12/01/2015 at 02:420 Comments
Turns out the Sonett transmission that I have is worn out. The bearings are shot. I'm going to get another one and see if that's good. A rebuild is $2,400 and up.
The floor in the trunk was swiss cheese. I cut the whole thing out. This should save me time in the end though because it means that I can make a custom battery box that will bolt in from the underside. That's awesome because I can just jack up all the batteries into place instead of lifting them into my trunk every time I need to trouble shoot something.
