Next steps
A project log for 18V DC current limiting power source
A 18V+ DC variable voltage, current limiting power source.
andr-wagnerAndré Wagner 11/10/2015 at 15:360 Comments
  1. Add voltage select to the design [DONE]
  2. Design the box [DONE]
  3. Solder the contacts [DONE]
  4. Test [DONE]
  5. Unsolder led and replace potentiometer [DONE]
  6. Drill holes in the box
  7. Cut hollow spaces in the box
  8. Add heat shrink sleeves to wires
  9. Solder everything
  10. Fixate to the box
  11. Test
  12. Close box
