Twenty minutes, and we're done
A project log for Spring clamp third hand for hand soldering SMDs
A quick-to-build spring clamp for holding SMD components down during hand soldering.
jenny-listJenny List 11/29/2015 at 15:170 Comments
A lengthy project log for a build that took twenty minutes from idea to completion is a bit pointless. My SMD soldering skills are probably average, I've built quite a lot of stuff over the years but I've always had problems keeping my components steady while I work on them. This clamp solves that problem with a very quick build and some readily available scrap.
The board in the picture is a pre-production prototype for my Pi-HF direct conversion radio receiver kit for the Raspberry Pi.
