Robot Arm
I always wanted a third arm
Construction of an open source precision five axis robot arm.
Design to handle a 10 Kg load.
Simple design using nylon plastics.
View all 2 project logs
  • 1
    Step 1
    Rotary Base Construction:
    Here is the rotary base. I machined a disk 8" in diameter and 1" thick from nylatron. I then cut out the internal shape and atached a Gates notched belt to the internal surface with Gorilla glue.
    The second 8"x8" nylatron blank was machined to hold the disk. The pinnion placement was measured and drilled for a perfect alignment to the internal ring gear.
    The disk sits on the base and turns very smoothly. The pinion has 12 teeth and the belt 116 teeth. This gives me a ~ 9.66 to 1 reduction.
    A window regulator motor is connect to the pinnion by a coupling.
  • 2
    Step 2
    The elbow joint is complete. A stainless steel cable will control the position and remove weight from the outer end.
View all instructions
Tr2sa wrote 12/08/2015 at 08:00 point
The inside use of toothed belt is nice idea. One has to be careful with belt load rating - typical number of teeth engaged is way higher (5...6), so there is need to downgrade maximum allowable load accordingly.
Joseph Lavoie wrote 12/08/2015 at 17:52 point
Yes the rotary base will be the only one with this design ; not alot of force on it.
