A new Oasis software is available
A project log for Oasis 3DP
A powder and inkjet 3D printer based on HP45 inkjet technology
yvo-de-haasYvo de Haas 05/21/2022 at 17:580 Comments
A new version of the software to control Oasis was added to the downloads. This is called "Oasis controller compact"
It works much the same as the old version of the software, but is more compact, has no text boxes as inputs, has selectable com ports (hit refresh if you do not see your port appear, tested in Windows, but should work on Linux) and an overfeed setting, which determines how much too far the feed piston goes up per layer added.
None of the features are groundbreaking, but I hope it will be of some use to people who have got an Oasis running.
