Improving efficiency
A project log for D.I.M.E.R PROJECT 6 DOF Robot Arm
This is my robot arm, with recycled materials, can pick 2 Kg and costs around 100$
antonio-regueiraAntonio Regueira 05/28/2016 at 22:070 Comments
Hi everyone, last weeks i thought about improving accuracy on the arm, one friend told me about putting springs so i read about this and it's a very good idea, putting some springs, motors needn't to work so hard, and can pick up more weight. i tried to make some skeches. It's only an idea and not the final result. what do you think about this? the motor would connect with the lowest gears with a gear ratio of 1/9.
And with this gears i can make force in both of direction, not only elevating.
I uploaded the file to my repository if you want it.
See you soon!
