Pointers and conditions
A project log for F-CPU
The Freedom CPU project has a log here too now :-)
yann-guidon-ygdesYann Guidon / YGDES 04/02/2024 at 01:410 Comments
The project is about more than developing a processor : it reconsiders the whole programming model.
This had already started with the YASEP, following all the concerns we had found with FC0. FC1 is the testbed for the POSEVEN programming model and I try to anticipate the requirements and consequences.
POSEVEN follows several of the #PDP - Processor Design Principles, in particular the principle that every resource of a given thread should be accessed by a single pointer, but it does not follow the "flat model" that Linux or Windows use. Historically, it could look similar to some old IBM mainframes.
The reason is to avoid "segments" at all costs since they are a false good idea that make life miserable in the end, because it's not RISC at all. But "canonical RISC" itself has its downsides. I'm exploring that with the definition of POSEVEN and I have come up with several  guiding principles.
The pointer's MSB is the private (1) / public (0) flag.
Threads can send pointers to other threads or blocks of code, but there is a need to protect "private data", just like in classic object oriented programming. The public addressing space is shared and accessed by every thread as a common pool, following rules enforced by paged memory protection. See later. The private space can only be accessed by the thread and contains all the necessary states.
The code and data spaces are strictly separated: this is a Harvard architecture.
Yet there must be a single pointer format to access all of it so the 2nd MSB means data (0) or code (1). No "normal" thread can access the code section as data, to prevent self-modifying code, exploration or alteration. This prevents introspection along with gadget-oriented exploits. Only a certain capability/right can write or read the code section during setup, to protect the integrity of the system, and this is not performed through typical data access to prevent hardware race conditions.
Stop for a moment. There are 4 combinations now:
The list is not yet finished but it's already a bit weird. What is "public code" ? It's a space where the processor maps trampolines/entry points to other software modules. Oh, I should have introduced that earlier.
A thread executes code provided and vetted by the operating system. There is no notion of program, driver, kernel : only modules. Every code is provided by a module and each module is mapped to a code space. Invocation of a module requires loading the module, mapping it to the appropriate space, fixing addresses etc. then the thread jumps (with a specific instruction : IPC) to specific addresses in the trampoline area, where the called module "filters" the request. This trampoline area is shared and accessible through the public space, though page mapping (specific to each thread) can make each module visible, invisible, or even redirect one module call to another module.
The IPC opcode provides a direct 16-bit offset into the trampoline to avoid indirect access and reduce the hardware complexity of invoking external code. This requires support from the OS but the implementation is fast and simple. This provides 64Ki instructions to jump to, and the jump must land on an IPE instruction, which provides extra information from the caller to the callee, such as thread id or eventual capabilities. To return from the callee, the code uses the IPR instruction.
As a consequence: a page for code has a granularity of 64Ki*4=262144 bytes.
There must also be a space that contains all the constants, in a read-only space that is shared by all the threads that execute the given module. This is not a candidate for the "public code" space because
Module constants may be mapped to the shared/public space or a s
The control stack is a third separate addressing space.
Yet another space is required for the control stack : is it neither code or data because the granularity is 2 words (either 2×32 bits or 2×64 bits).
This space can not be directly accessed : the control stack is a separate hardware/system and special instructions are required to read or write to it, if permitted by the thread's capabilities.
The thread can create its own software data stack to provide space for local variables : this is normally located in the private data space.
Normally, the control stack pointer is not accessible by the thread so there is never a dereference to a stack pointer. Thus there is no need to allocate an addressing space visible to the thread, however it must be mapped by the paging system.
_________
To support these features and others, the CPU must provide means to test a pointer. A certain class of condition codes is introduced to test the 4 MSB and 4 LSB of a register, because it can contain a pointer with metadata. The conditions
LSB0 (odd/even address, 16-bit aligned)
LSB1 (32-bit aligned)
LSB2 (64-bitaligned)
LSB3 (128-bitaligned)
MSB0 (private/public)
MSB1 (code/data)
MSB2
MSB3
are provided in the instruction set, they are easily implemented with a MUX and/or the "shadow" bits of the register set. A thread can easily verify that a pointer sent by another thread is valid and extract its properties (like the type of Aligned Strings).
