TCP Python code
A project log for IAQ WSN
We are building a wireless sensor network that is monitoring indoor air quality
vlapp17vlapp17 01/15/2016 at 09:060 Comments
We have tried to create a TCP socket, but this hasn't worked out.
import socket
import sys
import struct
import time
#main function
if __name__ == "__main__":
    host = "192.168.16.100"
    port = 22
#create an INET, STREAMing socket
try:
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
except socket.error:
    print 'Failed to create socket'
    sys.exit()
print 'Socket Created'
try:
    remote_ip = socket.gethostbyname( host )
    s.connect((host, port))
except socket.gaierror:
    print 'Hostname could not be resolved. Exiting'
    sys.exit()
print 'Socket Connected to ' + host + ' on ip ' + remote_ip
def recv_timeout(the_socket,timeout=2):
    #make socket non blocking
    the_socket.setblocking(0)
    #total data partwise in an array
    total_data=[];
    data='';
    #beginning time
    begin=time.time()
    while 1:
        #if you got some data, then break after timeout
        if total_data and time.time()-begin > timeout:
            break
        #if you got no data at all, wait a little longer, twice the timeout
        elif time.time()-begin > timeout*2:
            break
        #recv something
        try:
            data = the_socket.recv(8192)
            if data:
                total_data.append(data)
                #change the beginning time for measurement
                begin=time.time()
            else:
                #sleep for sometime to indicate a gap
                time.sleep(0.1)
        except:
            pass
    #join all parts to make final string
    return ''.join(total_data)
#get reply and print
print recv_timeout(s)
#Send some data to remote server
massage = "I'm here!!!"
try :
    #Set the whole string
    while True:
        message = recv_timeout(s)
        s.send(massage)
        print message
        print massage
        time.sleep(1)
        print 'Sending...'
    #Send failed
    print 'Send failed'
    sys.exit()
s.close()
