I found some matching gear motors for my mouse bot. And wheels which fit on the axes. The wheels are 32 mm in diameter. And the motors rotate with only a liitle start voltage up to max 6 volts. So I can use my stepless motor driver program with them. I hope this parts will arrive soon next week. Maybe I can modify the old motor holding plate to mount the new motors.
