Now I found out that the pins of a Propeller are to weak to switch an IRL 510. It seems that my Propeller died after switching the motors on. I now want to use a L298 dual H bridge motor driver from Solarbotics. It's sold as a kit. Then mousey II can drive forward and backward at different speeds.
