Shake out the jiggles!
A project log for Printrbot 'SuperSize Me" Mod
Transforming the humble 150x150x150mm stock print bed of a printrbot simple metal to a whopping 500x500x150mm
kendoken.do 02/13/2016 at 03:240 Comments
Although the printed bushing block was a good idea and may be functional with a bit of scaling, the wiggles have made me reconsider. After inspection, I found that the diameter of the bushings had increased just slightly, but enough to allow play. I may try to print out the actual bushing part with igus tribo-filament and somehow marry them to a PLA block. Meanwhile, I am swapped out to the measly 150mm again... However, the frame looks nice and the whole thing is super stable!!
