Navigation Chassis v0.2
A project log for Open Autonomous Domestic Robots
Open Autonomous Domestic Robots – An open source system for domestic cleaning robots using low-cost hardware
keith-elliottKeith Elliott 05/15/2016 at 21:313 Comments
Based on the results of the first motion test, I made several tweaks to the chassis for version 0.2.
IMG_0476
This is still very much a work in progress and there are still several things I’d like to add before I start working on the actual vacuum module, but I’m happy with the progress so far on the navigation chassis and think it’ll be complete enough to work as a test platform for navigation and mapping.
silvio biasiol wrote 05/16/2016 at 13:02 point
very nice design! May I ask how are you planning to build the vacuum module? :)
Keith Elliott wrote 05/19/2016 at 01:59 point
Surely!  I plan on 3D printing a dirt bin that plugs directly into the negative space in the navigation module.  For starters I'll put squirrel cage fan from Sparkfun (https://www.sparkfun.com/products/11270) to suck dirt into the bin.  Once I get that working I'll take a look at adding a beater bar in as well.
silvio biasiol wrote 05/24/2016 at 15:15 point
That's cool! Thank you :)
