April 26: UI common prefab for TA Variables
A project log for Watson Speech AI meets Unity 3D ScriptableObject
Connecting IBM Watson AI Speech-Text and Tonal Analysis web services with Unity3d ScriptableObject Data Architecture
jerry-isdaleJerry Isdale 04/27/2018 at 04:060 Comments
Took the Joy element from last revision and tweaked it a bit, then saved back to prefab and repositioned others.
New style uses the Panel's Text element to display a label, and a UI.Text element to display the value within the Filled element.  New script supersedes both Hipple ImageVar slider and the previous SOUI element.
