AirCore - Plug n' Play Wireless Serial
A lightweight module providing high speed WiFi data transfer. Native support for most uC. Clean and easy to use. ESP8266 based.
AirCore is an affordable and straightforward way to send and receive data from any microcontroller that has a Serial(UART) port. Forwards data through WebSockets to any device that has a modern browser, relying on its native support. This project aims to eliminate most of the frustrations encountered when using various commercial WiFi modules. Explores the struggles of creating my first product.
Introduction
AirCore is a module built to provide out of the box WiFi to Serial connectivity. By using an FTDI standard connector, this tiny board is capable of wireless programming of an Arduino, and it can be plugged in almost everywhere. Also, it can stream real-time data to a website for easy display, or even to another AirCore module. All the setup is done using an admin panel hosted on the module itself, similar to a WiFi router configuration. This saves hours of programming and testing lost in the quest of achieving basic functionality. Also, it reduces the uC overhead to a minimum.
Product features
  • Really transparent Serial to WiFi adapter
  • Lightweight - can be used on agile robots
  • Tiny, 26 x 16mm w/o connectors
  • High speed, real-time connection
  • User friendly, no coding required
  • Plug and Play connectivity
  • Analog and I2C headers
  • On-board 3.3V LDO
  • Use cases
    There are subjective reasons of why I want this module to work, and controlling a quadcopter for my bachelor's thesis is one of them. Another usage it would be to do data acquisition for a linefollower robot in order to improve it's algorithm. It will definitely be used to control an infinity mirror, and turning on the air conditioner from the internet before I get home would be nice(even if it requires some reverse engineering).
    Project goals
  • Improve existing ESP8266 based modules
  • Design and build an actually useful product
  • Achieve good RF performance using math instead of voodoo
  • Reduce module size as much as possible
  • Maximize throughput rate
  • Create a wireless programming plugin for Arduino IDE
  • Serve as a DFM guide, mostly based on community suggestions
  • Inspiration
    I copied or drawn ideas for my design from some places and I think they're worth mentioning here:
    • 1 × ESP8266EX Everybody's favourite WiFi Chip
    • 1 × W25Q80BLUXIG Memory ICs / FLASH Memory
    • 1 × AT8010-E2R2HAA 2.4GHz Micro Antenna
    • 1 × SPX3819M5-L-3-3/TR Power Management ICs / Linear Voltage Regulators and LDOs
    • 1 × FCX-06 26MHz Crystal Oscillator
    View all 14 components
    • ESP-Gzip Webpage compression
      Cristian Dobre02/24/2016 at 14:54 0 comments
      I finally took the time this week to refine my ESP-Gzip utility which I use to minify the website which will represent the user interface of the AirCore module. I have removed the 7za dependency and the compression is now done using node's own zlib API.
      Reducing payload
      The purpose of this utility is to reduce the website payload as much as possible by minifying and then compressing webpages using gzip. For example, the source website has 3712 bytes which the compressed file reduces to 1629 bytes. That means it's size has been reduced by more than 60 percent.
      First served webpage
      Even though I plan to develop a one page app to configure the ESP8266, I hate writing CSS and JS inside a single HTML webpage. That's why the utility supports inlining the resources at generation time, by including the #inline directive. This also minimizes the number of HTTP requests.
      <link href="css/styles.css#inline" rel="stylesheet">
      <script src="js/script.js#inline"></script>
      There are of course, disadvantages of using this method:
      • website is static, ESP8266 is blindly sending bytes
      • dynamic behavior requires WebSockets or AJAX
      • tool infancy, you will probably find bugs when using this extensively
      For HTTP interactions, I've published the esp_http library on GitHub. For now, it only supports HTTP requests.
    • Market analysis
      Cristian Dobre02/03/2016 at 12:34 0 comments
      Before starting any of the posts regarding the development process, some research needs to be done in order to see if the product is really needed by anyone. Spoiler: this will be quite a long post.
      Market analysis is an insight tool
      Most projects here focus just on the implementation of the idea they're based upon. Even so, the target audience can have important leverage on what your product should behave. Without a client for your product, you're left with an object in which you invested precious development time. It's important to gather feedback from similar products so we can know what to improve.
      As for this module, I want it to be connected to a fast moving robot, but other people may need it for totally different reasons. It's easy to be selfish and optimize the hardware for your own usage, but it will reduce the number of potential customers.
      Problem solving while finding your audience
      Let's say you have one of the popular WiFly module on hand, and with the help of an Arduino you want it to transmit data with as less delay as possible to a screen. Making an event based, simple HTTP request seems to be hard because of the examples provided and the number of lines of code you have to write. Let's list the major drawbacks and see where the AirCore module needs to improve:
      • Confusing hardware interface and setup
      • Programming is complex and time consuming
      • Overhead: microcontroller manages most of the protocol connection
      • Compatibility depends on the protocol you use
      Similar implementation using Bluetooth. Image courtesy of Adafruit
      Anyone who's got an Arduino knows what an UART or serial connection and has probably used an FTDI or CP210x module before. This has the advantage of being mainstream and straightforward because its used to program the Arduino Pro Mini's. There are only six pins on this interface, so it makes it a perfect candidate as the AirCore connector. Also, shiny breadboard friendly.
      To program the Arduino and WiFly to fit your needs, you need to have a knowledge base about microcontrollers, WiFi, HTTP and TCP. This is pretty much overwhelming just for sending some data, and I don't know a lot of people which can do it. So, the module needs to manage that overwhelming part in order to win some points. Familiarity is the key here: the module should be configured like a WiFi router.
      Overhead
      Image courtesy of O'Reilly
      Overhead is the most frustrating thing you encounter when using a WiFi module. You have to handle the protocol connection on your microcontroller, and it's often hard to do and not easily portable to another platform. Let's say I wrote my code and it works great on an Arduino, but if I wanted it on an ARM or Edison board, I need to rewrite. That's no a simple solution.
      Removing this overhead is the main purpose of the AirCore module. What if we can handle all the protocol details on the WiFi module and leave the microcontroller in peace because it has other things to do. This way, the only thing you need to worry about on your Arduino is spitting and receiving data from the serial pins solving the portability problem.
      Whenever you have incoming data over the internet, it needs to decode and process that information. TCP or UDP are raw connections, and if you didn't care about them when connecting AirCore module to your microcontroller, you certainly don't want to hear about them now.
      To be as Plug And Play as possible, the AirCore will use WebSockets. They're great and they have tremendous support. Every browser supports them, and you have a browser on your phone, computer and tablet.
    • Getting started
      Cristian Dobre01/28/2016 at 11:06 0 comments
      Some time ago, I had to build a wireless timer which had to display current time and lap times on a screen nearby. I've accomplished this back then using an WiFly RN-XV from Sparkfun, but the amount of coding required for the networking part was ridiculous. Especially because I had to read most of the RFC6455 in order to write a proper implementation. For another project, the library was updated to support multiple concurrent connections.
      The idea for a module like this came to my mind when I saw other people doing TCP transparent bridges using cheaper ESP8266 modules. Even though free, Espressif's SDK had a generous amount of bugs back then, so the idea was put on hold.
      The streaming protocol of AirCore relies on WebSockets implemented over a TCP connection. WebSockets have numerous advantages in terms of latency, communication speed and compatibility across different platforms. A WebSocket connection is a full duplex, persistent connection which has lower latency and less overhead compared to plain HTTP. And the protocol is supported by (almost) all modern Web browsers.
      Supressing bootloader output
      An annoying thing discovered while using the ESP8266 is the bootloader output which can't be disabled. You can swap the UART pins, but the TX remaps to MTDO which has to be held low during booting, so it would generate noise on the line. I have used a BSS138 Logic Level Translator on my board to toggle the ROM output, even though this occupies another GPIO pin.
    • Hello Hackaday
      Cristian Dobre01/25/2016 at 18:42 0 comments
      As this is my first project log, I'll try to make a proper introducement, then go into the details of why I chose Hackaday.io community to showcase my project.
      My name is Cristian, I am an undergraduate CS student. In the past two years, I've been heavily involved in the hobby robotics field here in my country. Along with my robotics team, we've managed to accomplish great things, like winning the 2015 Linefollower contest at RobotChallenge Vienna. I am big a fan of HaD and I've watched the blog for about half an year now.
      As any EE enthusiast, I am trying to make my own PCB for the ESP8266 chip which will complement the software and make it more attractive for end users in terms of usability. This project is more about designing a fully functional product from the feet up, than it is about software and hardware.
      As the project is going on, I'll try to explain every decision I make regarding usability, marketing, software and hardware and hopefully I'll receive great suggestions from experienced guys here in the Hackaday community.
    View all 4 project logs
    • 1
      Step 1
      Soldering
      Assembling the board proved to be the most difficult step. Hand soldering that damn ground pad under the ESP8266 never worked as expected because of the heat dissipation. Managed to get two chips soldered correctly by heating the chip to around 350 degrees C with the soldering tip, abusing them thermally. Bad practice, but they seem to be fully functional.
      Tried also with hot air, but it had fried my board before it would solder anything. I even simulated poorly a reflow oven temperature curve, but I couldn't get the board evenly heated on both sides so it didn't work.
      Fortunately, I did manage to get access to the university's reflow oven, which in Romania is harder than it seems. Then, blamed myself for not getting a stencil.
    View all instructions
    getyer157 wrote 01/10/2022 at 05:07 point
    This is looking very interesting idea and I think if you are looking for its online marketing then this platform is the best one for you.
    vjackie.sull wrote 09/10/2021 at 11:47 point
    Great idea I read the complete post and its really impressive I am also working in digital marketing company if you need this service visit here
    kelu124 wrote 10/21/2016 at 09:40 point
    Interesting !
    Dacian Vinereanu wrote 10/15/2016 at 11:43 point
    hi, what are the best latency obtained? Thanks
    Samuel Hollis wrote 07/07/2016 at 08:32 point
    Hi, I've been researching this module to see if it's possible to create a data acquisition system for out formula car for school. My idea is to have sensors through out the car and for those hard to wire places, to have the sensor wireless with an esp-12f module. The wired and wireless sensor would all come into a central unit for either data logging or transmission to a computer. Or maybe all the sensors should just go to a computer, I'm not sure yet. Any insight into if this would work? I'm looking for fast enough sampling rates for the results to be considered reliable.
    osannolik wrote 02/24/2016 at 16:08 point
    Very interesting! What kind of bandwidth or effective baudrate is practically achievable?
    Cristian Dobre wrote 02/25/2016 at 07:45 point
    Hello! In tests, I was able to get around 70kB per second using 1Mbaud for raw TCP data. Also, minimizing latency times effectively decreases the bandwidth.
    I will most certainly try some crazy baudrate figures even if they're not practical enough for most uC out there and transmission errors may occur.
