Posted at 11/11/2017 11:13:13 AM
A project log for Watchdog Security Camera Robot
Solar charges, Open build, affordable, watch and report or community presence robot.
josh-starnesJosh Starnes 03/22/2018 at 16:460 Comments
General Goals
- a mobile platform that can patrol a set routine
- Motion tracking , robot turns towards movement and tracks that object/ person
- 3-4 cameras recording 24 / 7
- run without outside power for at least 12 hours, but the goal is excess of 24 hours.
-Even in the even the robotic size of the electronics fails or the battery runs dead, there is a backup that keeps the cameras on and recording.
-Recording both locally on the robot itself and also wireless video sent to a recorder that I will probably setup with another raspberry pi.
- Live access to the cameras over the internet
- 1 tb hard drive dedicated to every camera, covers recording in HD for at least a rolling month. Recordings in 10 min intervals.
-Dual battery setup, one battery for the drive wheels , motor controller and ezb
Lithium battery 10,000 mah packs for each camera
-Safety Stop switch that cuts power to motor controller in the event of an emergency, but everything else still records.
-Create a water resistant area protected from spashing and weather for the electronics
-make some kind of seal where the panels come together
- Some kind of anti theft alarm, using geo location or other alarm to prevent theft
-GPS geofence alarm and active tracker
