Test 178m
A project log for PiCTDCL
Low cost underwater drop camera with lights, temp, pressure, and conductivity sensor
steve-haanSteve Haan 04/10/2018 at 19:220 Comments
did final do a test in Hood Canal by Triton at 178m (584') and it all worked fine. I did upgrade the Lexan from 1/16" to 3/8" just incase. Videos are up on YouTube. Did have a problem with wiring a couple days ago I'm using solid core wires and with pulling this out and putting it in the housing had a wire break from fatigue.
