• The Best One Transistor MW Radio Ever
    agp.cooper03/22/2018 at 02:08 8 comments
    Its a bold statement! Can you do better!
    It's the 636 One Transistor Reflex:
    And a video from the Internet:
    Another example:
    Here is my simulation of the 636:
    A number of changes were made:
    • Modified for 9v and crystal ear-piece output.
    • Added a 1k base resistor to stop "Colpitts oscillation".
    The schematic consists of:
    • On the far left, a the signal generator (before the the signal probe).
    • Then the short wire antenna model.
    • Then the tuning coil and tap at 10%.
    • Then the 636 circuit.
    Analysis:
    • The left analysis is of a 1 mv 1 Mhz signal modulated by a 1 Khz audio signal.
    • The audio shows a square law distorted audio output of 6 mv (a gain of x3).
    • The right analysis is of a 10 mv 1 Mhz signal modulated by a 1 Khz audio signal.
    • The audio shows a square law distorted audio output of 900 mv (a gain of 45).
    Replacing the 1 mH inductor with a 1k resistor, reduced the gain by a factor of 3:
    Increasing the tuning coil tap to 20% (from 10%) kills the tuning coil Q.
    Over to you!
