Hardware - First PCB
A project log for Light Room
Mood lighting meets dance party.
dhgoldbergdhgoldberg 04/28/2014 at 01:270 Comments
Hardware components on the PCB:
EagleCAD has a pretty steep learning curve, but thanks to some Sparkfun tutorials and other miscellaneous Google searches the PCB design process went pretty well.  I hand-routed each trace and it took a while before I had a layout I was happy with.
Thanks to OSH Park, two weeks after finishing the design I had three slick purple PCBs on my desk.
(insert image here)
A couple of changes noticed for the next revision:
Fortunately the board was pretty simple and there were no missing or mis-routed traces.  My big mistake was with the power supply.  I neglected to account for voltage drop over long cable runs, so sending 5V didn't cut it.  The next revision should take 12V or so and regulate it down to 5V.
In working on soldering my first smd components I learned, counterintuitively, that a larger iron tip can make soldering small components easier.  Who knew?
