PWM stage tested.
A project log for Mini Analog Quadcopter
Who needs bits and bytes to fly a quadcopter.
jlamJLAM 04/29/2014 at 11:250 Comments
So the idea behind the motor drive stage is a triangle wave generator with a op-amp acting as a comparator. The voltage reference signal will determine the PWM duty cycle. All this fits onto a quad opamp package. And to save weight I just soldered it dead bug style with SMDs. I also had dual N&P channel FET packages and had to drive one motor with a N and other with a P channel. It all worked out.
