Magnetic parts holder
A project log for DIY Pick and Place
Cartesian PNP machine using Rails/Carriages for high speed and accurate part placement. Affordable open source pick and place is on the way.
anthonywebbanthony.webb 01/27/2016 at 00:392 Comments
I designed a parametric model in Fusion360 for magnetically holding parts to the bed of our PNP. It has been built to allow you to specify how many lanes of parts you want, how wide the tape is, etc. From there it builds the body of your part which you can then either print or mill. For those of you who need something like this, or would just like to play around with the part, link is here http://a360.co/23rUlmW and the covers are here http://a360.co/1UriLHc
Malte R. wrote 02/08/2016 at 19:07 point
Hi Anthony, I finally finished my design of cut strip feeders + modular trays. Please find instructions and a link to download the STLs on my blog: http://malte-randt.de/strip-feeders-and-modular-tray-for-smd/
anthony.webb wrote 02/09/2016 at 16:09 point
Thanks Malte! I will check it out.
