Configure your audio device...
A project log for eXaDrums
Electronic drums for Linux
jeremyJeremy 10/08/2017 at 18:320 Comments
...without restarting eXaDrums.
The "Mixer Config" button is working and allows you to change your audio settings, such as buffer length, sampling rate, etc.
Below is a screenshot of the window that lets you do that:
As you can see, all the sound cards are detected and you can choose the one you want to use.
The best thing is that you don't even have to restart eXaDrums, you just select your sound card, set your parameters, click save and you're good to go.
I've been working on eXaDrums for over two years now and it's all coming together nicely. I try to publish most of what I do on HaD, but I sometimes skip a few things. Just to let you know the things I've been working on lately, here's a (incomplete) list:
The first three items can be found on Github. As for the last one, it's a bit of a tease, but I can already tell you that you can expect a demo on a real electronic drum kit at some point.
Cheers.
