Why existing power management sucks
A project log for Personal portable 3G router
A battery-powered router with enough features to be unique. WiFi, wired, 3G+ anything I'll need from OpenWRT on it.
aryaArya 02/05/2016 at 16:420 Comments
Hi!
Today I'm going to tell you about Alice's power management and power structure. As for today, it is like this:
It's pretty simple and mostly made of ready-to-go modules. This is one of my beliefs - projects like this are better if they're modular (modules are presumed to be easily available though). This reduces human error, decreases total effort necessary to build the thing for all the others and can serve as a learning material. In this case, I'll try to ensure this is a good learning material for anybody that'd like to build his own thing - or maybe even replicate my project. Now, with these intentions in mind, I'll start describing what I've constructed.
Description
First of all, Lithium-ion batteries. This is an excellent power source, not as scalable as others but you can build your own thing pretty easily. Research is the key though. Once you know, i.e. that you can't simply hook a Li-ion cell to a PSU to charge it, what PCM means and what it protects from, as well as acquire all the components necessary, there's one more widely available type of power source in your arsenal. For Li-ion, there's still a lot of theory behind not burning your house, so DO YOUR HOMEWORK BEFORE.
The magnets trick is a nice one.
I've got a lot of 18650 elements from laptop batteries, so I've decided to make them hot-swappable in addition to being chargeable while in the device. This way, I can minimise downtime in case of batteries getting flat and no power source being nearby - I tend to carry 18650 cells with me, as this isn't the only project powered by them =). The case limits me to 2 18650 cells, and 2s1p configuration would be tricky since I need balancing for charging them in a way other than out of the device - I don't have any balance charging modules that'd be as easy to use, and I couldn't use 5V to charge the battery without overcomplicating my setup, so paralleling cells is the way to go.
I don't need to (and I really shouldn't) solder wires to the batteries, so I needed a holder. However, all the pre-made holders are either bulky, expensive or both. I've made my own holders before, all you need is 2 pieces of metal - and a way to hold them tightly against the battery poles. Now I advise against these spring-loaded contacts you typically can salvage out of cheapest battery holders if you don't have a really tightly packed enclosure in which they can be securely fixed. In other words, don't use them if at least one of your contact groups has at least one axis of freedom.
I've bought a battery holder with nice flat yet strong contacts (spring-loaded also take more place) and embedded them in my case with hot glue and a couple of wires. Simple and takes less space than anything you can buy.
A CR123 holder, AKA the only one a local shop had that had this type of contacts and wasn't too expensive.
For charging and protection, I'm using the following module:
Disregard "5V-", it's GND. Battery GND is not GND, though, it goes through the protection module, so you shouldn't short it with GND.
Charging+protection module based on TP4056 IC. It's a linear Li-ion charger, only meant for 1sXp configurations and capable of handling no more than 1A (current configurable with R3), but that's enough for me since total capacity is about 3-4Ah (they've been salvaged from a laptop battery, after all). I also don't mind the heat issue, it doesn't have much heat-sensitive components around. It takes around 5 hours to charge from totally discharged batteries to full charge.
There's a difference between a module with protection and without. If you're building a simple charger and there's no consumer of the battery connected to it, you should be OK with an unprotected module. If it's a device, you want the cell protected so you get the module that includes protection. Both are useful so I try to keep enough of both types for all the chargers and devices I might build.
Once that's sorted out, we need a power input for charging. Since I've already defined that it needs to be 5V capable, there's a MicroUSB socket sticking out the case which, conveniently enough, is the socket on the charger board - I can simply make a hole for it, so that's what I did. It's in parallel with the IN pads on the charger board, and in parallel with the 5V input rail.
Also, as a feature, I have a switching DC-DC that will make the device be able to feed off various router PSUs. The more you are independent of the power sources, the better, so if I can use somebody's laptop PSU or just unplug the nearest TP-Link, that'll be great. The capacitor is rated for 25V, and the Vin max for DC-DC is 28V, and most power sources are in the safe zone. There's not enough protection on the input, though - that's bad, since it doesn't deal with reverse polarity and the cap has all the chances to blow up if I accidentally get a PSU with a different polarity. It's to be improved - most likely, with a MOSFET. Alternatively, with a plastic insert that shields all the circuitry inside from the capacitor's blast. Depends on the level of my laziness.
The 5V rail powers the charger, as well as the board while the battery's charging... Ah, about that.
The power source switchover part i the part where I've learned something neat while building, and for that I'm thankful to the #Hacker Channel. This is the trick with switching power sources from battery to USB when the USB is available. Why'd I need that? Simple, you shouldn't drain the battery while it's charging, otherwise it won't get the charging current as the load will be taking some. Not only that means slower charging, it also means that you'll never charge the battery completely as the current decreases over time near the end of charging, and at some point it's definitely gonna be on par with your load's consumption.... Also, why the hell you'd use any of the battery power when you've got a 5V source available? That's just crazy! So, I've made a circuit with a relay first:
That's the way I've posted it to the Hacker Channel, understanding it has to be overkill (relays are huge and I've never seen one in a mobile phone). I've received a couple of suggestions and kept them in mind. I've soon understood while testing that the relay scheme has a major problem - there's no power to the circuit while the relay's contacts are "in flight", and the AR9331 rebooted every time I'd plug the MicroUSB in. The online calculator said something about the capacitor's value that I'd need to power the circuit for the tough power switching times, and after estimating said capacitor's size, I've understood I might need a bigger box for the project to use relays, and een more if I want to have 3G connectivity. I've had to scroll through a week of chat logs.. Shame it doesn't have search!
One more problem - the relay is huge.
The circuit (appnote from Microchip on this approach) has 3 components necessary for the switching itself one of which was a MOSFET. I never had any experience with them before, so I had to read some appnotes on that, namely that one was useful. They appeared to be very well-written, but didn't include the clever way the FET was used in the circuit proposed - 'the other way around', if you wish (the explanation isin the article).
Flashback to the days when I didn't have to knowledge which parts I can replace with which and when, so I was almost sure I had to get every part listed right, as well as would be very confused when the BOM would say "any NPN transistor". Same with FETs - the knowledge on their usage can save you quite a bit of time, certainly more than just the ability to google around.
Anyway, I found the FET that was both suitable for the task and available locally (IRLML6401, if you're wondering), built a breadboard circuit to test everything... And got 250mV drop between drain and source while on battery power (so, a drop on battery-to-board path) which at 200mA is comparable to a Schottky in the same situation. Long story short, I decided to solder it onto a protoboard to at least make it permanent, after that the Vds dropped to 8mV. Lesson learned - not to trust breadboards too much. Or maybe it was wires. The breadboarded circuit is long gone, all that's left is lack of trust in breadboards and a jumper header between Vout and Vbat on the source switch board, in case I wanted to override the FET manually when I knew the power source wouldn't be connected (200mV is too much of a loss when you're squeezing out every minute out of the batteries and your voltage is around 3.7).
I'm sure this jumper would be a disaster to forget in the circuit if I were to connect 5V . I wonder if the protection circuit protects from 5V applied externally on battery's contacts, maybe some day I'll go to a forest nearby to test... I'd also gladly charge some certainly dead batteries - I like fireworks. Not to mention that I want to get some lithium fire extinguishing training before I get that unexpectedly... Batteries are complicated and dangerous.
A soldered prototype - I love mixing perfboards and SMD.
With the switchover circuit, the output we're getting will be from 3 to 5 volts with enough amperage to run the board (I haven't attached other parts of project like 3G or AVR yet, but it should be sufficient). The board is OK with voltage down to 3.2V, which should be plenty - there's an LDO and the CPU voltage s 3.3V. If there's a problem, I'll probably just power the board through a boost converter...
Checking if it works at all
Which is definitely needed for USB devices I'll be using. What a shame USB VBUS is not 3.3V... But that's just me complaining, things can't always be perfectly suitable. Anyway, I've gotten a boost converter module from eBay, and I should get more because these things seem to be very useful overall, with all the Li-ions. Liions. Lions. Heh.
So what I'm saying is - the boost I got has stated 3-5V input, so it seems to be perfectly suitable for my application. I've yet to test its efficiency - as well as actual suitable voltage range along with current. Speaking of which, I also need to test the capacity of my batteries, as well as put all the components together and see how much they consume. I probably will have to make a simple setup with Arduino and serial data transfer... It's never simple. I'll leave that for the next article.
Here you can see a couple of photos with the individual components already mounted:
Battery charger, new switchover circuit and the DC-Dc for higher voltagesHolding batteries securely in place with a flash drive cap
Looking for a place to put an Ethernet jack at
Assumptions/shortcomings made at this stage, or why does it suck:
Diagnosis - to be re-made to add all the protection missing, however good it looks or works. I've already ripped everything out, cleaned the boards, re-planned the wires and now it's gonna look nicer and work better.
I'm getting a 3G modem soon and I'll be testing that as well =) Power path control might be introduced in the next version, this prototype doesn't need one. It will have power monitoring, and that I'm working on right now.
Making sure everything fits and thinking about what else can be inserted
Logging the output of uptime command in a loop while on battery power
Ditto - it topped at 19 hours
I'm sorry for the delay in the updates. I'll start writing the next article tomorrow =)
