Coming clean :)
A project log for LiFePO4wered/Pi
LiFePO4 battery / UPS / power manager for Raspberry Pi
patrick-van-oosterwijckPatrick Van Oosterwijck 04/01/2016 at 16:143 Comments
Ok, I've decided to come clean on the dirty little secret about this project. :)
It's about the MCP73123 chip on the base #LiFePO4wered/USB module. I may have already alluded to this problem elsewhere, but it's time to fully document it. It also helps explain why it's a bigger deal than it should be to do a build.
Even though this project is built on top of a #LiFePO4wered/USB, the current stock I have that I'm selling on Tindie does actually not work as a base for #LiFePO4wered/Pi. The reason is that my #LiFePO4wered/USB was built using the MCP73123-22SI version that is commonly available in distribution. When I set out with #LiFePO4wered/Pi, I intended to use my #LiFePO4wered/USB stock and just add the top PCB. But my first prototypes that I made that way didn't work.
The reason is that the MCP73123-22SI version has a 6 hour "elapse timer". It will stop charging if the cell hasn't fully charged yet after 6 hours. The point of this feature is to stop charging in case the LiFePO4 cell is bad and doesn't take charge. Of course, the problem is that if the #LiFePO4wered/Pi is used as a UPS, the system will continuously draw current from the USB, not so much to charge the cell as to provide power to the Raspberry Pi. What would happen is that after 6 hours the charger would quit, then the battery would be used up and the Pi would shut down. Not much of a UPS that way. :-/
The solution is to use a different variant of the charging chip, the MCP73123-22JI. It has the elapse timer disabled, and works beautifully with the #LiFePO4wered/Pi. I created all my prototypes by removing the original chip from a #LiFePO4wered/USB and replacing it with a MCP73123-22JI instead. This is fine for some proto's, but not for production of course. So instead of being able to use my existing stock, I'll actually have to do a new #LiFePO4wered/USB build as well, in addition to the #LiFePO4wered/Pi add-on boards... Unfortunate, but that's the way it is.
davedarko wrote 05/10/2016 at 08:42 point
So what happens if you cut off the power supply and hook it up again? I'm thinking of using this with a bicycle dynamo - whenever you'd make a stop, it wouldn't charge anymore, so I wondered.
Patrick Van Oosterwijck wrote 05/10/2016 at 16:08 point
It will keep running the Pi from the battery when you stop.  For about an hour with a RPi 2 or 3 and up to 4 hours for a Pi Zero.
Bjarke Aagaard wrote 05/03/2016 at 12:28 point
Oh well, looking forward to you will be taking orders!
