Last few days for the KickStarter - Final Design
A project log for PiAngle Zero - Not just another Pi Zero USB Hub
A plug-n-play 4 port USB hub for the Pi Zero - No soldering required! Also provides a power source for the Pi
sean-hodginsSean Hodgins 03/01/2016 at 15:550 Comments
Final design with the added ESD protection and new USB Micro plugs. The plugs make the board 6mm closer to the Pi. Works well.
KickStarter down to its last days... 4 to go!
Its going to be really close, but hopefully we'll get some coverage somewhere for the final days! Check out the KickStarter and share with your friends!
https://www.kickstarter.com/projects/idlehandsdev/piangle-zero-usb-power-and-4-port-hub
