"Little Raspberry" watching You!
I'm watching you while you sleep : )
This project is for my cousin who is "night walker" :) Mostly he don't remember what he was doing, so i'm preparing this little project for him. Without internet ofcourse :))
I will use Camera HD with Night Vision (wide angle) + IR for recording and mayby some Servo to follow object if camera won't be enough to embrace full room. USB HDD to put recorded video on him (i want to record in high quality so it will need more space). And Raspberry Pi with camera interface, would be nice to use Pi Zero but can't :(
Stand for camera i will print by my own and later i will link images and upload .stl files if someone will need.
I still need to learn a lot about Raspberry so it will be my first project and i hope i will make it! (Good thing is there's a lot materials for RPi to help me out! :) )
plug.STL
Covering GPIO port :)
Microsoft Trust UI Provider - Certificate Trust Link - 143.64 kB - 02/03/2016 at 14:36
Download
Front.STL
I did some my modifications to this case (link to original file you can check in links). Wanted to have easier access to GPIO + changed logo on top.
Microsoft Trust UI Provider - Certificate Trust Link - 2.53 MB - 02/03/2016 at 13:58
Download
Back.STL
Back is also from the guy who made front so you can check links on the left (i just removed VESA mounts)
Microsoft Trust UI Provider - Certificate Trust Link - 3.93 MB - 02/03/2016 at 13:58
Download
  • 1 × Raspberry Pi with camera interface important! :)
  • 1 × Camera HD NightVision H + IR wide angle
  • 1 × Servo SG90 (?) if needed
  • 1 × SD CARD min. 8GB I'm using SanDisk 16GB class 10
  • 1 × USB HDD We will see how much space i will need for ~8h video :)
  • RPi 2 case
    Mateusz Formicki02/03/2016 at 16:25 0 comments
    Printed Raspberry Pi 2 case with easy access to GPIO + plug to hide it if don't need.
    Probably will change it someday to something better :)
    I cut plug a bit because he didn't want to fit in slot good, but with little work its good now!
View project log
