New Arduino shield PCB
A project log for DIY programmable (SCPI) bench power supply
Bridging the gap between professional and DIY/hobbyist bench power supply
denisDenis 02/12/2016 at 10:350 Comments
A new PCB is created in accordance with issues mentioned in the previous post. I'd like to highlight few more details:
The schematic can be split into four sheet with the following circuits:
Dimensions of the new PCB are now 204 x 76 mm and it occupy most of the back side of the front panel:
New Arduino shield will require redesign of remaining PCBs that I'll post here gradually.
