If you ain't Wifi-in', I ain't dyin'
A project log for 8 Leaf Pi Zero Bramble
Modular design, small footprint Pi Zero Supercomputer
txdomsktxdo.msk 02/14/2016 at 21:130 Comments
After rebooting from that, I hooked up the ethernet and an old WIFI dongle that I KNEW would work, and made sure that I could move to the kitchen table (Gotta watch that the chili won't bubble over!)
I used putty to ssh into the Raspi B via the ethernet connection and then enabled the wifi dongle:
setup the wifi on /etc/network/interfaces
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
setup the wifi on /etc/wpa_supplicant/wpa_supplicant.conf
network={
ssid="Whatever Your ESSID IS"
psk="YOUR WIFI PASSWORD"
I Let the Raspi B simmer for a bit, and discovered that the Wlan0 adapter picked up and IP address from my router just as well as you please...
Once I had the IP for the wifi, I used that address in a putty terminal to verify it did work. NOTE: Wifi is NOTICEABLY slower than a native ethernet connection, but I am stuck on this, as I don't have much left to buy the right equipment (the wifi adapters were cheap, I knew they worked, and I wanted to make sure I had SOME connectivity at least, since I now couldn't get ethernet that I KNOW will work and it would take too long for me to solder them up).
