Case design idea
A project log for Pi ZERO Arduino programming station
Just a PiZero Pocket Computer case, with ability to plug any available Monitor (Component Video, HDMI, LCD) and a keyboard via USB HUB
sergeySergey 02/09/2016 at 16:280 Comments
So, I was thinking about something like yoga-type device case with velcro attached, so that you can attach LED or HDMI monitor a keyboard of your choice. On the other side of foldable panale is a solar panel, so that you can put a device with screen towards you and it will be still charging using the solar on the back side, even when you are using a keyboard, you can lay down with solar towards the sun. The idea is simple, but designing such a thing totally outside of my abilities and experience. :(
