Components
A project log for Pi ZERO Arduino programming station
Just a PiZero Pocket Computer case, with ability to plug any available Monitor (Component Video, HDMI, LCD) and a keyboard via USB HUB
sergeySergey 02/17/2016 at 16:190 Comments
So, I'm starting to understand the project is either DIY or something I don not have skills for. Compact case prototyping requiring a lot of PCBs with extra small size which require SMD soldering and I'm not good at that.
So, DIY project.
Currently playing with Software parts on Raspbian Qemu image (Adafruit WebIDE didn't work - required Kernel options which are not in the quemu kernel, trying Pydio now, works like a charm on Raspberry actually, like it so far but looks to heavy for my project, will try to utilize some parts of it)
So, surfed the web in a search for hardware components. For now I'm thinking about the following:
So, with that we have pocket device, with charging ability, solar charing (or pretty much any other powerfull enough source), UART pinout, I2C Pinout, ISP pinout. Also some sort of GPIO still available (preferrably in the unchanged Raspberry GPIO header), 4 USB ports, HDMI port, Video-Out port
Thinking about creating a super tiny querty keypad on the top side of the device. So that you just need to plug one of these super cheap I2C OLEDs and start doing your stuff.
