Final Housing Design
A project log for Coffee/Tea Cooling Buddy
Monitor the temperature of your drink and know when it reaches the perfect temperature. Even generates a tiny bit of electricity too!
scott-clandininScott Clandinin 06/23/2018 at 06:230 Comments
See the 3D design here.
I designed a new housing for it to be more aesthetically pleasing and with small improvements. I moved the copper screw hole closer to the front so the thermoelectric generator sits it a more optimal place between the copper and the heat sink. Secondly I raised the assembly a bit higher so the copper would  not be touching the surface of the table.
This was modeled in Autodesk Fusion 360, and printed with with a Craftbot + with PLA. The print time was about 20 hours. There are standoffs built for a 40mm x 60mm prototype circuit board.
