Log 4: Verify that Picamera Works
A project log for Control Mechanism of an Autonomous Quadcopter
Obstacle detection system by OpenCv on Raspberry Pi 2 Model B
canberk-suat-gurelCanberk Suat Gurel 02/11/2016 at 12:540 Comments
Make sure you have enabled the camera by
sudo raspi-config
(If you don't know how to do this take a look at Log 2.)
raspistill -o cam.jpg    # take a picture with the raspberry picam
raspivid -o video.h264 -t 10000    #record a video (for 10s) with picam
Use
ls -l
command to verify "cam.jpg" and "video.h256" are there.
pcmanfm &
command to open the documents folder of the raspberry pi
[VISUAL!]
there should be the picture you've just took (named as cam.jpg) double click on that to open the picture
also the video (named as video.h264) that you've recorded is located in the same directory.
