NEJE PCB Exposer
Pimp up the "neje" style engraver to expose UV sensistive PCB
This is currently only a scribble.
First i have to envestigate the laser driver....
The "NEJE Diy Mini Engraver" (google it or aliexpress it) is sold in basically different forms: Open Gantry style and Framed Enclosre style.
To my knowledge there is no official manufacturer for it. The hardware design seems to be derived from this project -> http://www.instructables.com/id/Pocket-laser-engraver/ .
My model is "Open Gantry style".
It consists basicall of the following parts:
- Outer frame to hold it all together
- A "300mW" 405 nm laser assembly (incl. driver circuit)
- Two DVD Frames with motors/spindles and head carrier
- Two "schmalzhaus" easy stepper drivers based on allegro a3967 ics
- An Arduino Mini "Clone" board
- A "motherboard" PCB for wiring up all these components and for a ULN2003 darlington array which is used to switch the laser on and off
  • Burning up the photoresist
    Gnathonemus07/03/2016 at 15:20 0 comments
    The first trials with showed that the movement of the laser head is to slow:
    "Burning" a pcb layout did exactly that:
    the photoresist was burnt so it stuck to the board, during the development process, instead of dissvoling as expected.
  • Inspect/Mod laser driver
    Gnathonemus07/03/2016 at 15:14 0 comments
    The laser (driver) is drawing 267mA at 5V.
    Added a transistor/resistor to laser driving circuit to toggle laser.
View all 2 project logs
