Tests with microphone module
A project log for Bone transduction hearing aids
This project proposes a solution to hearing problems, creating a device which uses bone conduction.
jos-luisJosé Luis 04/03/2018 at 02:580 Comments
Not having a good performance with the preamp module, I went to a store specializing in electronics, looking for a module that detects the sounds. The only module I found for that purpose was ky-038, which is a module that uses an electret microphone to pick up sounds, ranging from 100 Hz to 10 KHz, covering the detection range of the human voice, incorporates itself into an operational comparator amplifier, the LM393. This module works from a voltage of 3.3V and offers an analogous output for the range of 1Vpp.
When connecting and testing with the horn, an improvement in the detection of sounds is perceived, having a less saturated sound and without noise.
When testing with the "bone transducer", it is possible to perceive the sounds, although somewhat weak. The part of this prototype was satisfying, since with simple elements we could perform the corresponding tests, and see that the idea is functional.
For the following tests it would be necessary to make several improvements, which are:
