OSCUS - A HACKABLE OS
OSCUS, a hackable OS for hardware hobbyists, is COMING.
iTardis, an IrDA transmitter with touch pads.
To demonstrate the features of OSCUS, I design a board with a 4x4 bi-color led matrix.
Each led represents a task and the color of the led represents the state of the task.
-RED: the task is suspended
-BLUE: the task is ready-to-run
-BLINK: the task is running
The board also features:
-beep buzzer
-IrDA receiver
-temperature sensor
-micro SD
-key button
-external pinhead
So we can create tasks for each features, for example, task15(priority 0xF) for key button scanning, task14(priority 0xE) for buzzer, task8(priority 0x8) for sensor.
Then we can observe how the OSCUS works, including task execution and inter-task communication, etc.
As an embedded engineer, I like schematic, layout, coding, debugging. I also except to understand various concepts of OS, for example, task, semaphore, message queue, scheduling, etc.
So OSCUS is coming. It's a hackable OS for hardware hobbyists. It's neat and tiny.
The code line is about 1K and just need a little amount of RAM about 100bytes to run.
So it is very easy to understand and use for those who are interesting in OS concept.
It features:
- Co-operative multitasking, without complex stack management
- Two-level scheduling mechanics, priority-based(maximum eq 0x04)
- and round-robin in each priority level(maximum eq 0x04)
- Maximum task number eq 16
- Rapid task switch, time complexity O(1)
Task Model:
- Task priority ranges from 0x00 to 0x0F
- When there are no tasks in the higher priority level group, controller will be give to tasks in the lower priority
- When two or more tasks have the same priority, controller will be given to the next after the previous run-to-completion
- Task 0 as idle routine, must be defined
**      Round-robin scheduling in each group
**      | F | E | D | C |    - priority level 3  - highest    | Priority-based
**      | B | A | 9 | 8 |    - priority level 2               V scheduling
**      | 7 | 6 | 5 | 4 |    - priority level 1
**      | 3 | 2 | 1 | 0 |    - priority level 0  - lowest
Here is the schedule lookup table and routine for 4x4 tasks.
First we search the highest priority group, then each ready-to-run task in the group will be invoked round by round.
So we can implement the schedule time complexity O(1).
 crByte const crDskTbl[][CR_RR_PPL_NUM]={
            0x00,0x00,0x00,0x00, /*0:0000*/
            0x00,0x00,0x00,0x00, /*1:0001*/
            0x01,0x01,0x01,0x01, /*2:0010*/
            0x01,0x00,0x01,0x01, /*3:0011*/
            0x02,0x02,0x02,0x02, /*4:0100*/
            0x02,0x00,0x00,0x02, /*5:0101*/
            0x02,0x02,0x01,0x02, /*6:0110*/
            0x02,0x00,0x01,0x02, /*7:0111*/
            0x03,0x03,0x03,0x03, /*8:1000*/
            0x03,0x00,0x00,0x00, /*9:1001*/
            0x03,0x03,0x01,0x01, /*A:1010*/
            0x03,0x00,0x01,0x01, /*B:1011*/
            0x03,0x03,0x03,0x02, /*C:1100*/
            0x03,0x00,0x00,0x02, /*D:1101*/
            0x03,0x03,0x01,0x02, /*E:1110*/
            0x03,0x00,0x01,0x02};/*F:1111*/
 void crTaskSched()
    crByte BitX,BitY;
    //crAssert("crTskSched begin:0x%02x\r\n", crRdyTskGrp != 0x00);
    BitY = CR_DBIT_FSB(crRdyTskGrp);
    BitX = CR_DBIT_NXT(crRdyTskRow[BitY], crRdyTskCol[BitY]);
    crRdyTskCol[BitY] = BitX;
    crRdyTskIdx = CR_BIT_OR(CR_BIT_LSHIFT(BitY,2), BitX);
    //crAssert("crTskSched end:%d\r\n", crTskTbl[crRdyTskIdx].entry != (void*)0x00...
View project log
glensongg wrote 03/23/2018 at 11:10 point
Hi bobricius,
OSCUS supports max 4*4 tasks and two-level scheduling mechanics, priority-based and round-robin.
So the 4 rows of the led matrix represent the priority level, and the 4 columns represent the round-robin tasks in each priority level.
Through the led state of the matrix, we will easily understand show the OS works, including task execution, scheduling, semaphore, message, etc. :)
bobricius wrote 03/23/2018 at 06:54 point
I think better is 5x3 matrix to display characters 4x4 for what?
