Testing, Part 1
A project log for Blinkenrechner
Computer based on a homemade 8-bit CPU
grant-giesbrechtGrant Giesbrecht 08/11/2021 at 17:330 Comments
All of the PCBs have been assembled, now I'm assembling the computer and testing each system as I install each board.    I started off powering up the system board to make sure everything looked okay. I'll be connecting each module to this as the central hub.
System Board Test
Nothing burning so far...
The first major system I tested was the RAM. I had to change two bias resistors to pull-down from pull-up because I made an error in one of my logic circuits, but otherwise it's good to go.
Testing RAM
After a small fix, the RAM is up and running.
Next I tested the flash memory. I'll need it to run any test programs, so I'll need it working reliably before I can test any more exciting systems (*coughs* CPU). I found a bug in one of the data protection circuits - an RC timer is connected to a buffer without hysteresis and causes ringing on the output. Fortunately, this system is somewhat unique in that the ringing is extremely unlikely to cause a problem, but if I make a new revision of the board, that will be one of the first things to change.
Testing Flash
Flash memory works!
Then I installed the control panel. There's not a whole lot to test until I've connected more boards, but already you can see some of the completed systems lighting up :)
