tools I really want to make / have
davedarkodavedarko wrote 12/10/2016 at 10:20 • 1 min read • Like
Starting this list to remind me that I want tools like this and that they should be fairly easy to make.
pressured air thing
to blow away dirt and dust
tiny vacuum chamber
for getting out the bubbles in 2K epoxy covered things
shaker
for shaking solvents like ABS + Acetone
vibration mini table
bubbles / shaking / etching you name it
Like
Alex wrote 12/10/2016 at 18:52 point
I am also thinking about a small vacuum chamber. Found this.: https://www.amazon.de/Vacuumsaver-BRO-1A640-Vakuumbehälter-BoroSilikat-Pumpe/dp/B00URLR2A8/ref=sr_1_1?ie=UTF8&qid=1481395833&sr=8-1&keywords=Vacuumsaver+BRO-1A640+Vakuumbehälter,+BoroSilikat+mit+Pumpe+-+BoroSeal,+640+ml
So far I did not bought it and I am also not sure how much vacuum you can generate with that.
davedarko wrote 12/10/2016 at 19:03 point
interesting - this could probably be done with a normal vacuum cleaner as well. Just cut a whole in a box and be careful not to suck it in :D
deʃhipu wrote 12/10/2016 at 17:46 point
I think you can get most of this stuff at a sex shop ;-)
davedarko wrote 12/10/2016 at 19:05 point
first thought was airbrush equipment, but you're spot on. Suction thingies and vibrators. I still have a vibration motor from one, so vibration plate is easily done.
