And now, JavaScript !
A project log for micro HTTP server in C
Connect your browser to your smart devices, using a minimalist HTTP compliant server written in POSIX/C
yann-guidon-ygdesYann Guidon / YGDES 05/09/2020 at 00:340 Comments
The latest revision is working, at least from the C side.
Now is the time to evolve the client side, with the creation of a JavaScript client side.
So far the keepalive mechanism is working well but there is just one issue : the page can be opened in two tabs of the same web browser...
I need to find a trick to prevent this !
20200511:
The root HTTaP object includes a new element : "HTTaP_open" is 0 when /? is first accessed, and 1 subsequently.
It is up to the client to detect this situation and avoid loading anything else to prevent disruption of the already established connection.
20200514:
I have also solved the problem of dangling/open connections when the page is closed or reloaded !
