Vinduino, a wine grower's water saving project
Monitoring soil moisture at different depths to determine when to irrigate,
and - more importantly - how much water is needed. Save 25%!
If you want to learn about saving water, talk to a farmer. California farmers, including myself, voluntarily aim to reduce agricultural water consumption by 25%. This reduction (25% of 42 million acre feet/year) is more than the annual urban water use (8 million acre feet/year), much more effective than any residential water reduction can achieve.
The Vinduino project (Vineyard + Arduino) started out of necessity to better manage irrigation in my Southern California vineyard.
In order to be of the greatest possible use to the public, the Vinduino project is open source, affordable, and easy to build.
In 2015 we saved 25% , or 430,000 gallons, of irrigation water.
Cost saving on water and labor was $1,925.
Cost to achieve these savings was $635.
Minimum configuration for developing countries, incl. salinity measurement: $ 60.
36 countries are now classified as severely drought affected.
Saving water makes all the sense in the world. Hope you will be inspired too!!
Project Goals
Provide low cost, easy to build, and rugged components for optimizing agricultural irrigation
  • DIY calibrated gypsum soil moisture sensors (Watermark SS200 is also supported)
  • Hand held sensor reader (soil moisture, soil/water salinity, water pressure)
  • Solar powered remote sensor platform (Vinduino R3)
    Options include:
    • 4 electrically separated inputs for soil moisture sensors
    • Wifi (ESP8266) or Globalsat LM-210 LoRa module for long range (6 miles)
    • Irrigation valve control, optional pressure sensor for valve operation feedback
    • several options for temperature/humidity sensors
    • Built in solar battery charger
    • Built in real time clock for precise irrigation timing
  • Gateway to connect multiple LoRa end nodes to the Internet via Wifi (Vinduino Gateway)
Support the following use cases
  1. Easy entry/lowest investment/good water efficiency
    Walk around manual field measurement of sensors, use data for adjusting irrigation timing
  2. High automation level/low investment and maintenance/best water efficiency
    Automated irrigation adjustment with Internet data presentation/control
How does this project save irrigation water?
Using a single soil moisture sensor, you can determine when to start irrigation, but overwatering is hard to avoid. This is illustrated with the animation below. By the time the irrigation water reaches the sensor, the layer above is saturated and likely there is more water than the plant can consume. The surplus water will now seep below the root zone, out of reach of the plant, taking unused nutrients with it as well.
By using multiple sensors, located at different depths, you can actually control irrigation to not exceed the active root zone,
and thus save water. Rather than to irrigate for long periods and have long periods between irrigations, it's better to have short, frequent irrigation events. The plant will be able to take up the irrigation water before it has a chance to reach the level below the active root zone. Sensor 3 should be located lower than most of the active root system. When sensor 3 sees high moisture levels, its a signal to reduce water/increase interval frequency. Sensor depth and watering schedule depends on the type of crop and growth cycle.
For vineyards, irrigation reduction is sometimes practiced in the period before harvest to get highly concentrated wine grape material. The idea is that the best wines come from vines that have suffered water stress.
Sensor interface design considerations
Resistive sensors, like gypsum or Watermark sensors, need to be excited with short pulses of alternating current to avoid electrolysis effects. The Vinduino interface alternates current through the sensor, and two analog inputs are used to measure voltages over the bridge. This compensates for differences in (battery) supply voltage, and also allows to compensate for sensor bias voltage.
A lesser known fact is that sensors can act as small batteries due to a galvanic effect caused by a difference in concentration within the sensor. For details see: concentration cell. This effect happens with gypsum - as well as commercial Watermark sensors, and can severely affect DC bridge measurement accuracy. One solution is to average out by measuring with two analog inputs.
Because the sensors are connected together through a soil resistance path, multi-sensor measurements can only be done when sensors are disconnected when not in use. Vinduino uses regular 2N7000 FETs for this. The handheld reader can measure only one sensor at a time, and therefore can use a simpler interface circuit without FET switches.
The Vinduino project's deliverables:
  • 1 × 8 characters x 2 lines LCD display AMC0802BR-B-G6WFDW
  • 1 × Arduino Pro Mini
  • 2 × resistor 4k7, 1% reference resistors used in sensor measurement bridge
  • 1 × resistor 470 Ohm LCD backlight current limit
  • 1 × 10 k potentiometer LCD display contrast setting
View all 11 components
  • Raspberry Pi LoRaLAN gateway for Vinduino
    Reinier van der Lee12/24/2016 at 17:00 0 comments
    LoRa Sensor Gateway
    The Vinduino gateway receives LoRaLAN sensor data from the Vinduino sensor stations and forwards via WiFi to a ThingSpeak account.
    To date, the Vinduino project has been using an Electric Imp solution, which required some soldering and PCB assembly.
    The following project update, describes a gateway that uses a LD20-H USB LoRa dongle from Globalsat, and does not require any electronics tinkering. This dongle is basically a USB version of the Globalsat LM-210 LoRa module used in the Vinduino sensor station, and, alike the module, works as a wireless UART. Combined with a serial terminal program, this dongle also makes a great debug tool to check out the LoRa network and sensor stations.
    The Vinduino LoRa gateway can handle up to 300 sensor stations within a range of 5 miles, and can be made for less than $100, assuming that an old PC’s useful life can be extended for the task of working as gateway. Because the software is based on the operating agnostic Python-3 programming language, the supported PC platforms that can function as gateway include Windows, MacOS, Ubuntu Linux , and of course Raspberry Pi. For increased traffic handling, more USB dongles can be added, working on different frequencies.
    The Python-3 gateway script, although tested to be working reliable for its basic gateway function, can be customized/improved as needed. For locations where access to Internet is not reliable, or intermittent, we added a SQLite database to store all sensor data locally.
    One possible application could be to store data locally and upload when an internet connection is available. This may also be a good starting point for developing smart irrigation algorithms.
    The Globalsat LD20-H is available on Tindie
    PS: This LoRaLAN gateway is not compatible with LoRaWAN sensor stations.
    LD-20H features
    • Ultra-high sensitive receiving ability by LoRa spread spectrum modulation technology
    • Long-distance transmission (1KM to 10KM)
    • Easy to use and easy to configure
    • Multiple dongles for multi-channel gateway
    • Programmable parameters:
      • Frequency: 862-1020 MHz
      • RF data rate: 0.81K, 1.46K, 2.6K, 4.56K, 9.11K, 18.23K bps
      • Max TX power: 5-20 dBm (100mW max)
      • UART baud rate: 1200-57600 bps, parity non, odd, even
    Installation
    Python modules needed for the Vinduino gateway script:
    1. serial
    2. time
    3. thingspeak (linux install: $ sudo pip3 install thingspeak)
    4. sqlite3
    DB browser for SQLite (http://sqlitebrowser.org) is a great program to manage the SQLite database.
    Linux install: $ sudo apt-get install sqlitebrowser
    For Windows, install the Cypress USB serial driver
    For Linux:
    Linux does not require a special drivers for the USB serial interface, however ensure that you have qt4, gcc, and libusb installed. The USB driver stack in Linux has a built-in driver for CDC-ACM class devices. The Cypress chip inside the LD-20 supports CDC-ACM class, CDC-ACM driver gets automatically bound to the device and creates a device node in /dev/ttyACM*(* -The name of device node will vary based on the number of devices connected).
    Here is a good description for testing the USB serial connection in Linux:
    http://www.cypress.com/knowledge-base-article/testing-usb-serial-bridge-controller-configured-usb-uart-linux-kba92551
    I found that Ubuntu and RPI recognized the USB serial port, but assumed it was an AT-command modem.
    A solution that worked for me is to bypass the ModemManager:
    sudo systemctl mask ModemManager.service
  • Vinduino LoRa LAN Gateway
    Reinier van der Lee09/24/2016 at 22:20 0 comments
    This project log entry covers the LoRa gateway that receives and forwards data from Vinduino sensor stations to the ThingSpeak website where it can be displayed as graphs.
    The gateway is based on the Electric Imp 1 and the matching April development board. Other components include a Globalsat LM-210H LoRa radio module, antenna, and Vinduino Gateway PCB. The unit works fine with a regular 5V USB wall adapter as power supply.
    During this year's field trials we were able to make reliable data connections over a distance of up to 7 miles (10 km) under line of sight conditions.
    As the Vinduino gateway is only receiving data, range can significantly be increased by using directional antennas without violating FCC regulations. The sensor stations (transmitting) only use the FCC approved antennas.
    The Vinduino sensor stations are default set to 15 min transmission intervals. This allows for a max of 300 sensor stations to be supported by one single gateway, provided there is collision avoidance in the software.
    We tested with multiple gateways and multiple stations this Summer in Temecula wine country, and found no issues with multiple gateways simultaneously receiving data from the same sensor station. The ThingSpeak network server accepts the first message and rejects identical messages coming within 15 seconds.
    Components
    The gateway is based on the Electric Imp 1 and its matching April development board, available at Amazon.com for around $20.
    Other components include a Globalsat LM-210H LoRa radio module, antenna (available at Tindie.com as add-on option for the Vinduino sensor station board), and Vinduino Gateway PCB, available at OSHPark at this link: Order board
    The unit works fine on a 5V USB wall adapter as power supply.
    Programming
    Before you can program the unit, you will need to set up an account at electric imp and connect the electric imp using their interesting "Blink Up" procedure. The Electric Imp website has an excellent tutorial, so no need to elaborate here.
    The editor is on line. You can change the software on-line and then activate it to run without physical access to the unit. There is a programming section that runs on the host system of electric imp (Agent), and there is a programming section for the device itself.
    The latest code can be copied and pasted from the Vinduino Github page: Vinduino-GW
    Luke Beno (analog.io) was the original author, and he kindly agreed to release it to the public domain.
    I modified his code to make it work with ThinkSpeak.
    Testing the gateway and monitoring
    The Electric Imp editor has a logging window that is very useful for the initial bring-up and monitoring of the gateway and stations data. As shown below, the device section displays the data as it is received from the sensor stations.
    The sensor data comes in readable format. After the channel ID (blurred out in the picture below, there are 4 data fields for soil sensor 1-4, battery voltage, temperature, and
    When received and processed correctly by the ThingSpeak server, there is a response from ThinkSpeak with an incrementing number representing the number of correct data lines received for that particular ThinkSpeak channel.
    Results
    We tested during a full growing season in the Temecula wine region this year with 20 Vinduino sensor stations and 10 gateways, all operating at 915 MHz. Most of the issues encountered were related to the soil moisture sensors and their installation, not the sensor stations or the gateway. Although the 915 MHz ISM band is heavily used, we have not experienced interference from other users.
    The use of LoRa technology without the overhead of the full LoRaWAN stack can be sufficient for use cases that only need monitoring of non-confidential sensor data over longer distance. For secure bi-directional communications, LoRaWAN may be a better option, but -as always- this comes at higher cost and complexity.
  • Selling on Tindie!!
    Reinier van der Lee07/28/2016 at 02:20 0 comments
    Removing one more obstacle for growers to save irrigation water and cost. We are selling online!!
    Vinduino remote sensor platform optimizing agricultural irrigation https://goo.gl/QRyVNu
  • To Spray or not to Spray? Adding Anemometer
    Reinier van der Lee07/17/2016 at 21:12 0 comments
    For farmers who have remote fields, it's critical to know the wind speed conditions before setting up the equipment and riding out to spray. Too much wind , and you cannot accurately deliver the "goodness". Basically wasting time and materials and risk contamination of the surrounding properties.
    Luckily adding a wind speed sensor ( anemometer) to the Vinduino sensor station is an easy task. We used an Adafruit active anemometer with an analog output or 0.4 - 2 V. There are also passive anemometers with an intermittent contact interface. I prefer the active model as an analog read can be done very fast, and that helps to save battery power. The anemometer requires 12V or higher to operate, and the Vinduino station works with a single 3.8V Li ion battery.
    So we added an external DC/DC boost converter module. For this example, we used a low cost SMAKN 5V to 12V module, available at Amazon.
    To save battery power, the Vinduino system is kept in sleep mode until the RTC wakes it up. The Arduino then runs through the sensor measurements and sends the data via a LoRa radio modem to the Internet. We do not need to keep sensors powered on during the sleep period.
    The Vinduino board has a load switch chip that can switch battery power to the accessory connector J13. The load switch is controlled using Arduino digital pin 13 (ACC_EN).
    See Github for the full Vinduino schematic diagram. Below shows the simple wiring diagram for connecting the boost converter and anemometer.
    The anemometer electronics take about one second to start up and stabilize after power is switched on.
    Windspeed calibration is taken from Adafruit data that 0 m/sec = 0.4V out ,and 32.4 m/sec at 2V. Because there is a small temperature drift, the wind speed < 0.2 m/sec s reported as 0.
    Here are some initial results. So far, we only had moderate wind speeds during testing.
  • 50% Irrigation Water Saved at Veraison
    Reinier van der Lee07/09/2016 at 18:32 0 comments
    Veraison is here in Temecula!!
    Veraison represents the transition from berry growth to berry ripening. An important milestone for grape growers.
    The young green berries are still high in acidity, and hard to the touch. When the color of the berry changes, multiple changes start taking place. The skin becomes thinner, the color turns to purple, and the composition of the acids changes. Also, important for the alcohol level of the future wine, the berry sugar content increases. We're about two months from harvest now. Time to prepare for crush season.
    Our goal for this season is to save 25% water and provide data for other growers helping with their irrigation decisions. By managing irrigation depth to percolate water only into the active root zone, we saved 50% irrigation water thus far this season vs. the two previous years. This is based on data we get from the water district.
    We monitor soil moisture in and below the root zone, using our home-grown Vinduino system, to make sure that the vines have enough water to stay healthy and productive. After all we are growers!
    Apart from damage from excessive heat that affected many vineyards in the area a few weeks ago, the vineyard looks good.
    Below is a picture of the Vinduino gateway, which relays data from the remote sensor stations on the LoRa network via WiFi to the Internet.
  • LoRa network module review
    Reinier van der Lee06/05/2016 at 23:37 1 comment
    In this update, I cover experiences with 3 different modules, all using the same Semtech SX1276 LoRa chip, designed for use in the 915 MHz license-free band in the US and 868 MHz in Europe. The first generation of Vinduino remote sensor stations used ESP8266 WiFi modules. They work great in and around the house, but lack the range for agricultural work.
    With the LoRa modules evaluated, a range of up to a few miles is easily achieved with standard "rubberduck" antennas and line of sight. When using antennas that provide gain, you can get some serious distance. When testing with a 9 dB gain directional antenna on the balcony, and a loRa module with a standard antenna mounted on my car roof, I got a 6 mile range. A Finnish team from the university of Oulu reported 30 km (20 mi) range over water and 15 km over land using standard antennas.
    My requirements for the Vinduino telemetry were: long range (>1 mile), easy to work with, FCC approved, license free frequency use, robust communications, and low cost.
    ModelArduino compatibleFrequencyFCC approvedEstim price
    APC220yes430 MHzNo$14
    APC340yes915 MHzNo$27
    LinkLabs
    LL-RLP-20
    Arduino Mega915 MHzYes$44
    Globalsat
    LM-210
    yes915 MHzYes$25
    Before introduction of the ESP8266, the APC220 was the module of choice for making wireless Arduino projects.
    They work as transparent wireless UARTS, serial data in = serial data out. Very easy to work with. Range of this module is just block away, and not being FCC aproved made me look at a new arrival from the same company, Appcon in Shenzen, APC340. I ordered some samples and they worked great, the only thing missing was FCC approval.
    Next module evaluated was a new module from LinkLabs, also using the same Semtech LoRa chip as the APC340, and FCC approved. There is even an Arduino sketch available, but unfortunately this only works for their Symphony LoRa WAN architecture. You can write to the registers for making it work as a wireless UART, but that mode is not supported and not FCC approved.
    Finally, I met with the folks of Globalsat at CES. They were introducing a new range of products for LoRa and LoRa WAN, and all their products have FCC approval.
    I have been using their LM-210 module for a few months now and had good results with field testing. The 915 MHz band has many users, all doing some kind of spread spectrum modulation. For use in Europe, I was able to program the module to work at 868 MHz, at 14 dBm output level. The LM-210 uses spread spectrum modulation as well, distributing the signal over 125kHz. Viewing with a SDR radio, the radio signal looks like this:
    The radio link includes forward error correction, and in most situations that works well enough. In situations where the signal strength is not enough to maintain the connection, errors can slip through. To maintain data integrity in challenging environments it's therefore better to have a CRC check in the software.
    The LM-210 connects with a 7-pin header. The I/O voltage should be 3.3V, the supply voltage can be up to 6V, but to be sure, I operate Arduino and LoRa module at 3.3V.
    Working with the modules is straightforward, data in = data out. The interface bitrate comes as default 9600 bps. The RF signal rate can be programmed between 0.81 and 18.23 Kbps. RF output power is 20 dBm (100mW), and can be reduced in 7 steps of 2 dB.
    The module has two mode selection pins, that are pretty interesting to play with.
    Mode 1, Pin 1=0 and Pin2=0: the channel is opened and the module is active. This is also the mode with highest power consumption: 13 mA typical for receive and 120 mA for transmit.
    Mode 2, P1=0 and Pin2=1: difference with mode 1 is that every transmission now starts with a preamble needed to wake up a receiver in wake-up mode (see mode 3), and RSSI data is added.
    Mode 3, P1=1 and P2=0: Power saving mode. The receiver is in sleep mode and wakes up at a set interval. If a transmission preamble is detected, receiving starts until the transmission is ended.
    Mode 4, P1=1 and P2=1, Setup mode. Changing...
  • Using a Solder Paste Stencil
    Reinier van der Lee03/20/2016 at 17:37 3 comments
    For upcoming trial installations, I need 25 Vinduino printed circuit boards. Not a sufficient enough quantity for cost effective outsourcing of assembly. The new version of the Vinduino board has a good number of SMD components, and after building the first board with solder paste, toothpick, and hot air tool, I knew I had to find a faster way. So when I ordered PCBs @ Elecrow.com, I clicked on the option for having a 30 x 40 cm framed metal stencil. Added cost for the metal stencil is $18 + shipping, a bargain!
    The PCBs and stencil arrived one week later, and I was pleased with the quality of the stencil and the frame. Now I was in the market for a stencil printer. A unit with good reviews will cost you over $500 + $200 shipping (weighs 17 kilo) from China. The $150 units on Ebay get mixed reviews, so was not sure if I wanted to squander HackaDay prize money on that.
    I ended up not buying a stencil printer (for now), but instead made a $20 wooden positioning frame that works accurately, and gives repeatable results.
    To fix the position of the PCB, I used iron-on edge tape. Then I moved the frame until it was perfectly aligned with the PCB pads. The frame position is fixed with pieces of wood glued to the base board.
    For first tests, I used low temperature lead free solder paste, and a putty knife to apply the solder paste. One single pass should be enough.
    The method gets me good solder paste dosage, and accurate alignment.
    Fresh from the T962A oven, all solder pads passed visual inspection. Looks much cleaner than the manually applied solder paste build I did on the very first board.
    No rework was needed.
    After assembly of the top side through-hole components, all boards work as expected.
  • More green coming to vineyards soon
    Reinier van der Lee03/13/2016 at 16:07 0 comments
    It's March, and we have budbreak in our vineyard. Spring is in the air, smell of jasmin everywhere.
    This is a great time to be in the vineyard.
    We were hopeful that this Winter would see a lot of rain, but so far El Nino did not bring the much needed relief from a multi-year drought.
    There is more fresh green coming to vineyards this year. In preparation of the new season, and with help of our Hackaday friends and Analog.io, the Vinduino project has been developing a new generation of the Vinduino soil moisture monitor.
    The new Vinduino R3 (Remote, 3rd generation) has the following features:
    • 4 inputs for (gypsum) soil moisture sensors
    • built in (solar) battery charger
    • support for 6 mile long range (Globalsat LM-210, LoRa) radio module or ESP8266 WiFi
    • clock module for precise irrigation timing
    • on board temperature and relative humidity sensor
    • accessories port for optional irrigation valve control and extra sensor
    • power management circuits, resulting in lower power consumption
    • open source (of course)
    For LoRa operation, we are developing a low cost gateway capable of handling 300 end nodes within a 6-mile radius.
    More on that later.
    Vineyard trial installations start next month. We'll keep you updated on our progress.
  • Planning ahead to replace gypsum sensors
    Reinier van der Lee03/06/2016 at 19:34 1 comment
    Gypsum sensors slowly dissolve in water, and while doing so provide a salinity level around the electrodes that makes the sensor less sensitive to soil salinity.
    While their active life may be a few years, gypsum sensors will not last forever. So while installing, it's good to plan ahead for their replacement.
    The way I installed my sensors before is show below, using pipe couplers at the end of the required length PVC pice.
    In this case, I installed sensors at 2 feet, 4 feet, and 5 feet depth.
    Pulling them out improved an impossible task, as the couplers provide too much friction in the soil. The only way to replace is dig them out.
    A solution is to forego using couplers, and integrate the sensors with the pipe.
    The PVC pipe can be stretched to a wider diameter after heating with a heat gun. I found a temperature of 150-175C, makes the PVC flexible enough without burning or releasing fumes. A hot air rework stations works fine for this.
    After stretching, let it cool at it's wider diameter and place the sensors inside. Then heat the pipe again. The PVC pipe will shrink around the sensor, forming a tight fit after cooling. Now removing a sensor pipe is "only" a matter of applying sufficient force.
  • Vinduino Low Power Wide Area Network
    Reinier van der Lee02/21/2016 at 21:47 0 comments
    We are hard at work to get first vineyard trial installations done by early April.
    Too busy for frequent update logs, but here's a snapshot of what's going on.
    There will be an updated design for the Vinduino remote node. See picture below.
    Updates include:
    • 4 sensor inputs (previously 3)
    • integrated RTC
    • integrated battery charger and solar panel support
    • lower power design
    • support for Globaltech LM-210 LoRa radio modem (licence free 915 MHz band)
    • lower cost components
    As I am still working on finalizing the schematics and PCB, there is no update on Github yet.
    Below schematic is not finalized, but provided here for a high level impression.
    Range experiments using the FCC approved GlobalTech modules show a range of at least 6 miles. I had one unit set up on the balcony of our house in Temecula, and the other unit was connected to a GPS receiver on the roof of my car, reporting GPS coordinates and RSSI (radio signal strength) every 10 seconds. The data was imported in Google maps, showing the coverage. See picture below.
    Basically, for all the wineries located around the main winery road, Rancho California road, there is good coverage. There is another wine trail road, De Portola, that does not have full line-of-sight coverage from my vineyard location. Based this data, we assume that the whole wine region can be covered with a star topology using only 2-3 central hubs. Assuming hourly transmissions per node, we can support up to 300 remote nodes per hub.
    In collaboration with Luke Beno's Analog.IO project we are step-by-step resolving the issues of managing a network of this scale.
View all 30 project logs
  • 1
    Step 1
    Make a gypsum soil moisture sensor
    Components needed for one sensor:
    • 2 x stainless steel machine screws, 6 - 32 x 2
    • 6 x stainless steel hex machine nuts, 6 - 32
    • 1 x piece of window screen glass fiber mesh (5 x 10 cm)
    • 1 x plastic spreader (1.5 x 2.75 cm), holes for screws 1.25 cm apart
    • 1 x plastic top cover 3.5 cm diameter, holes for screws 1.25 cm apart
    • gypsum powder (Plaster of Paris)
  • 2
    Step 2
    for casting needed:
    • 1 x 3/4" PVC pipe coupler
    • painters tape
View all 3 instructions
elkhateebmohamed856 wrote 4 days ago point
شركة ظواهر الخليج لكشف تسربات المياه هي الرائدة في مجال الخدمات المنزلية في المملكة العربية السعودية. تقدم الشركة مجموعة واسعة من الخدمات التي تشمل كشف تسربات المياه، تنظيف المنازل، عزل الاسطح والخزانات، وتسليك المجاري. تتميز شركة ظواهر الخليج بفريق عمل متخصص ومعدات حديثة، مما يضمن تقديم خدمات عالية الجودة تلبي احتياجات العملاء بأفضل صورة ممكنة. تسعى الشركة دائمًا إلى تحقيق رضا العملاء من خلال العمل بكفاءة ودقة، وضمان الحصول على نتائج متميزة ومستدامة.
كشف تسربات المياه بالرياض:
تعد مشكلة تسربات المياه من أكثر المشاكل شيوعاً في المنازل والمباني السكنية بالرياض، والتي يمكن أن تؤدي إلى أضرار جسيمة في البنية التحتية والممتلكات. لذلك، يعتبر كشف تسربات المياه بالرياض خدمة حيوية للحفاظ على سلامة المباني وضمان عدم حدوث أضرار مستقبلية. تشمل هذه الخدمة استخدام تقنيات حديثة مثل الكاميرات الحرارية وأجهزة الاستشعار الصوتية لتحديد مكان التسرب بدقة وفعالية، مما يسهل عملية الإصلاح ويوفر الوقت والجهد.
شركة كشف تسربات المياه بالرياض:
تقدم شركة كشف تسربات المياه بالرياض حلولاً متكاملة وفعالة لمشكلة التسربات المائية في المنازل والمباني التجارية. تتميز الشركة بفريق من الخبراء المختصين في كشف التسربات باستخدام أحدث التقنيات والأدوات لضمان تقديم خدمة دقيقة وفعالة. بالإضافة إلى ذلك، تلتزم الشركة بتقديم خدمة عملاء ممتازة وتوفير تقارير مفصلة عن حالة التسربات والإجراءات اللازمة للإصلاح. تعتمد الشركة على مبدأ الشفافية والجودة لضمان رضا العملاء وتقديم خدمات متميزة تفوق التوقعات.
شركة كشف تسربات بالرياض:
إذا كنت تبحث عن شركة كشف تسربات بالرياض، فإن هناك العديد من الشركات التي تقدم خدمات متميزة في هذا المجال. تعتمد الشركات المتخصصة في كشف التسربات على أحدث التقنيات والأجهزة لتحديد مواقع التسرب بدقة وفعالية، مما يساعد في تجنب الأضرار الكبيرة التي قد تلحق بالمباني والبنية التحتية. تقدم هذه الشركات خدمات شاملة تشمل الفحص، التقييم، والإصلاح، بالإضافة إلى تقديم استشارات ونصائح للحفاظ على المباني من مشاكل التسرب المستقبلية. إن اختيار شركة موثوقة ومتخصصة يضمن لك الحصول على خدمة ذات جودة عالية ونتائج مضمونة.
نحن في الشركة الدولية للخدمات المنزلية نلتزم بتقديم أعلى مستويات الجودة والاحترافية في خدماتنا لعملائنا في المملكة العربية السعودية. نقدم مجموعة شاملة من الخدمات المنزلية، بما في ذلك كشف التسربات، والتنظيف، والعزل، وغيرها، بأحدث التقنيات بفريق متخصص ومدرب. نحن هنا لتلبية احتياجاتكم وتوفير بيئة منزلية آمنة وصحية.
كشف تسريبات المياه بحي الملك فهد:
إذا كنتم في حي الملك فهد ويواجهون مشاكل في التسربات، فنحن في خدمتكم. نقدم خدمات كشف تسريبات المياه بحي الملك فهد بمنتهى الاحترافية والجودة، مستخدمين أحدث التقنيات لتحديد مصادر التسرب بدقة وإصلاحها بشكل فوري. اتصلوا بنا اليوم للحصول على حلول فعالة ودائمة لمشكلات التسربات في منزلكم.
كشف تسريبات المياه بحي الملك عبد العزيز:
نحن هنا في حي الملك عبد العزيز لمساعدتكم في حل مشاكل كشف تسريبات المياه بحي الملك عبد العزيز في منازلكم. باستخدام أحدث التقنيات والمعدات، نقوم بكشف وتحديد التسربات بدقة، ثم نقوم بإصلاحها بشكل سريع وفعّال. اعتمدوا على فريقنا من الخبراء لضمان حل مشكلتكم بأقصر وقت ممكن وبأعلى جودة.
كشف تسريبات المياه بحي الياسمين:
في حي الياسمين، نحن متخصصون في كشف وإصلاح التسربات بكفاءة عالية. نفهم أهمية الحفاظ على منازلكم من التلف الناجم عن التسريبات، ولذا نقدم خدماتنا بأعلى مستويات الجودة والاحترافية. اتصلوا بنا اليوم للحصول على خدمات كشف تسريبات المياه بحي الياسمين التي تلبي احتياجاتكم وتضمن سلامة منزلكم.
كشف تسريبات المياه بحي الرحمانية:
إذا كنتم في حي الرحمانية ويعانون من مشاكل التسربات، فلا داعي للقلق، فنحن هنا للمساعدة. بفضل فريقنا المتخصص والمجهز بأحدث التقنيات، نقدم خدمات كشف تسريبات المياه بحي الرحمانية بدقة عالية وفعالية مضمونة. اتصلوا بنا اليوم لحل مشكلات التسربات في منزلكم بأسرع وقت ممكن.
كشف تسريبات المياه بحي حطين:
نحن شركة متخصصة في كشف وإصلاح كشف تسريبات المياه بحي حطين. يعمل فريقنا المدرب بجد واجتهاد لتقديم خدمات عالية الجودة لعملائنا. باستخدام أحدث التقنيات، نحدد مصدر التسريب بسرعة ونقوم بإصلاحه بشكل فوري، مما يضمن سلامة وأمان منزلكم.
كشف تسريبات المياه بحي الملقا:
في حي الملقا، نقدم خدماتنا المتميزة في كشف وإصلاح التسريبات. نفهم أهمية الحفاظ على منازلهم وممتلكاتهم، ولذا نعمل بجد لتوفير حلول فعالة ودائمة لمشاكل التسربات التي قد تواجهكم. اعتمدوا علينا لتقديم خدمات كشف تسريبات المياه بحي الملقا ذات جودة عالية وبأسعار معقولة.
كشف تسريبات المياه بحي الدار البيضاء:
إذا كنتم في حي الدار البيضاء وتبحثون عن خدمات كشف تسريبات المياه بحي الدار البيضاء، فإننا هنا لمساعدتكم. نقدم خدماتنا بأعلى معايير الجودة والاحترافية، باستخدام أحدث التقنيات والمعدات. اتصلوا بنا اليوم للحصول على حلول سريعة وموثوقة لمشاكل التسربات في منزلكم.
نحن في [url=https://foamisolation.com/]الشركة الدولية للخدمات المنزلية[/url] نلتزم بتقديم أعلى مستويات الجودة والاحترافية في خدماتنا لعملائنا في المملكة العربية السعودية. نقدم مجموعة شاملة من الخدمات المنزلية، بما في ذلك كشف التسربات، والتنظيف، والعزل، وغيرها، بأحدث التقنيات بفريق متخصص ومدرب. نحن هنا لتلبية احتياجاتكم وتوفير بيئة منزلية آمنة وصحية.
إذا كنتم في حي الملك فهد ويواجهون مشاكل في التسربات، فنحن في خدمتكم. نقدم خدمات [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%83-%d9%81%d9%87%d8%af/]كشف تسريبات المياه بحي الملك فهد [/url]بمنتهى الاحترافية والجودة، مستخدمين أحدث التقنيات لتحديد مصادر التسرب بدقة وإصلاحها بشكل فوري. اتصلوا بنا اليوم للحصول على حلول فعالة ودائمة لمشكلات التسربات في منزلكم.
نحن هنا في حي الملك عبد العزيز لمساعدتكم في حل مشاكل [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%83-%d8%b9%d8%a8%d8%af-%d8%a7%d9%84%d8%b9%d8%b2%d9%8a%d8%b2/]كشف تسريبات المياه بحي الملك عبد العزيز[/url] في منازلكم. باستخدام أحدث التقنيات والمعدات، نقوم بكشف وتحديد التسربات بدقة، ثم نقوم بإصلاحها بشكل سريع وفعّال. اعتمدوا على فريقنا من الخبراء لضمان حل مشكلتكم بأقصر وقت ممكن وبأعلى جودة.
في حي الياسمين، نحن متخصصون في كشف وإصلاح التسربات بكفاءة عالية. نفهم أهمية الحفاظ على منازلكم من التلف الناجم عن التسريبات، ولذا نقدم خدماتنا بأعلى مستويات الجودة والاحترافية. اتصلوا بنا اليوم للحصول على خدمات [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%8a%d8%a7%d8%b3%d9%85%d9%8a%d9%86/]كشف تسريبات المياه بحي الياسمين[/url] التي تلبي احتياجاتكم وتضمن سلامة منزلكم.
إذا كنتم في حي الرحمانية ويعانون من مشاكل التسربات، فلا داعي للقلق، فنحن هنا للمساعدة. بفضل فريقنا المتخصص والمجهز بأحدث التقنيات، نقدم خدمات [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d8%b1%d8%ad%d9%85%d8%a7%d9%86%d9%8a%d9%87/]كشف تسريبات المياه بحي الرحمانية[/url] بدقة عالية وفعالية مضمونة. اتصلوا بنا اليوم لحل مشكلات التسربات في منزلكم بأسرع وقت ممكن.
نحن شركة متخصصة في كشف وإصلاح [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%ad%d8%b7%d9%8a%d9%86/]كشف تسريبات المياه بحي حطين[/url]. يعمل فريقنا المدرب بجد واجتهاد لتقديم خدمات عالية الجودة لعملائنا. باستخدام أحدث التقنيات، نحدد مصدر التسريب بسرعة ونقوم بإصلاحه بشكل فوري، مما يضمن سلامة وأمان منزلكم.
في حي الملقا، نقدم خدماتنا المتميزة في كشف وإصلاح التسريبات. نفهم أهمية الحفاظ على منازلهم وممتلكاتهم، ولذا نعمل بجد لتوفير حلول فعالة ودائمة لمشاكل التسربات التي قد تواجهكم. اعتمدوا علينا لتقديم خدمات [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%82%d8%a7/]كشف تسريبات المياه بحي الملقا[/url] ذات جودة عالية وبأسعار معقولة.
إذا كنتم في حي الدار البيضاء وتبحثون عن خدمات [url=https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d8%af%d8%a7%d8%b1-%d8%a7%d9%84%d8%a8%d9%8a%d8%b6%d8%a7/]كشف تسريبات المياه بحي الدار البيضاء[/url]، فإننا هنا لمساعدتكم. نقدم خدماتنا بأعلى معايير الجودة والاحترافية، باستخدام أحدث التقنيات والمعدات. اتصلوا بنا اليوم للحصول على حلول سريعة وموثوقة لمشاكل التسربات في منزلكم.
نحن في <a href="https://foamisolation.com/">الشركة الدولية للخدمات المنزلية</a> نلتزم بتقديم أعلى مستويات الجودة والاحترافية في خدماتنا لعملائنا في المملكة العربية السعودية.
حن <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%83-%d9%81%d9%87%d8%af/">شركة كشف تسربات المياه بحي الملك فهد</a> نقدم خدماتنا بمهنية عالية وبأحدث التقنيات، لضمان اكتشاف وإصلاح أي تسربات بدقة وفعالية.
حن <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%83-%d8%b9%d8%a8%d8%af-%d8%a7%d9%84%d8%b9%d8%b2%d9%8a%d8%b2/">شركة كشف تسربات المياه بحي الملك عبد العزيز</a>، متخصصون في تقديم خدمات كشف وإصلاح التسربات بدقة وفعالية. يعاني الكثيرون من مشاكل التسربات في منازلهم،
<a href="https://tkgc-ksa.com/">شركة ظواهر الخليج لكشف تسربات المياه</a> هي الرائدة في مجال الخدمات المنزلية في المملكة العربية السعودية.<br />في حي الياسمين،
تقدم <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%8a%d8%a7%d8%b3%d9%85%d9%8a%d9%86/">شركة كشف تسربات المياه بحي الياسمين</a> بمهنية ودقة عالية. نحن نفهم أهمية الحفاظ على سلامة منازلهم وممتلكاتهم،
<a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d8%b1%d8%ad%d9%85%d8%a7%d9%86%d9%8a%d9%87/">شركة كشف تسربات المياه بحي الرحمانية</a> يتطلب خبرة وتقنيات متطورة، وهو ما نقدمه في شركتنا بكفاءة عالية.<br />يعتبر <a href="https://tkgc-ksa.com/">كشف تسربات المياه بالرياض</a> خدمة حيوية للحفاظ على سلامة المباني وضمان عدم حدوث أضرار مستقبلية.<br />تقدم <a href="https://tkgc-ksa.com/">شركة كشف تسربات المياه بالرياض</a> حلولاً متكاملة وفعالة لمشكلة التسربات المائية في المنازل والمباني التجارية.<br />نحن <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%ad%d8%b7%d9%8a%d9%86/">شركة كشف تسربات المياه في حي حطين</a>، نفتخر بتقديم خدماتنا ذات الجودة العالية والموثوقة.<br />تقدم <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d9%85%d9%84%d9%82%d8%a7/">شركة كشف تسربات المياه بحي الملقا</a> بأعلى معايير الجودة والمهنية. اعتمادكم علينا يضمن لكم راحة البال والثقة في جودة الخدمة المقدمة.
نحن في <a href="https://foamisolation.com/%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%ad%d9%8a-%d8%a7%d9%84%d8%af%d8%a7%d8%b1-%d8%a7%d9%84%d8%a8%d9%8a%d8%b6%d8%a7/">شركة كشف تسربات المياه بحي الدار البيضاء</a> نفتخر بتقديم خدماتنا المتميزة والموثوقة في مجال كشف وإصلاح التسربات.
إذا كنت تبحث عن <a href="https://tkgc-ksa.com/">شركة كشف تسربات بالرياض</a>، فإن هناك العديد من الشركات التي تقدم خدمات متميزة في هذا المجال. تعتمد الشركات المتخصصة في كشف التسربات على أحدث التقنيات والأجهزة لتحديد مواقع التسرب بدقة وفعالية،
centercall502 wrote 06/07/2021 at 17:30 point
هوم سيرفس للخدمات المنزلية
نجار بالرياض رخيص
نجار ابواب
فني نجار بالرياض
نجار خشب بالرياض
نجار بالرياض شاطر
شركة تركيب ستائر بالرياض
شركة تركيب مطابخ بالرياض
فني تركيب مطابخ بالرياض
شركة تركيب طارد حمام بالرياض
شركة مكافحة حمام بالرياض
شركة تركيب ستائر بجازان
نجار بجازان
شركة تركيب اثاث ايكيا بجازان
شركة تنظيف مكيفات بجازان
شركة تركيب غرف نوم بجازان
شركة تركيب طارد حمام بجازان
شركة تنظيف منازل بجازان
شركة تنظيف شقق بجازان
شركة نقل اثاث بجازان
شركة نقل عفش بجازان
شركة تركيب باركيه بجازان
هناجر
سواتر
مظلات
مظلات جدة
مظلات مكة
شركة مكافحة حشرات بالدمام
شركة مكافحة حشرات بالخبر
شركة مكافحة حشرات بالقطيف
شركة مكافحة حشرات بحفر الباطن
شركة مكافحة حشرات بالاحساء
شركة مكافحة حشرات بالجبيل
شركة نقل عفش بالدمام
شركة نقل عفش بالقطيف
شركة نقل عفش بحفر الباطن
شركة نقل عفش بالخبر
شركة نقل عفش بالاحساء
شركة نقل عفش بالجبيل
شركة تنظيف منازل بالدمام
شركة تنظيف منازل بالاحساء
شركة تنظيف بالجبيل
شركة تنظيف بالخبر
شركة تنظيف بالقطيف
شركة تنظيف بحفر الباطن
centercall502 wrote 06/07/2021 at 16:58 point
شركة تنظيف منازل بجدة
شركة تنظيف بجدة
شركة تنظيف شقق بجدة
شركة تنظيف فلل بجدة
شركه تنظيف منازل بجده
شركه تنظيف بجده
شركه تنظيف شقق بجده
شركه تنظيف فلل بجده
تنظيف منازل بجدة
شركة تعقيم بجدة
شركة تنظيف خزانات بجدة
شركة غسيل خزانات بجدة
تنظيف خزانات بجدة
شركة تنظيف بالبخار بجدة
شركه تنظيف بالبخار بجدة
شركه تنظيف مجالس بالبخار بجده
شركة تنظيف موكيت بالبخار بجدة
شركة تنظيف مكيفات بجدة
شركة تنظيف مكيفات سبليت بجدة
تنظيف مكيفات بجدة
شركة مكافحة حشرات بجدة
شركه مكافحة حشرات بجده
شركة مكافحة الفئران بجدة
شركة مكافحة النمل الابيض بجدة
شركة رش مبيدات بجدة
شركة مكافحة بق الفراش بجدة
شركة كشف تسربات المياه بجدة
شركه كشف تسربات المياه بجده
كشف نسربات المياه بجدة
شركة كشف تسربات بجدة
شركة كشف تسربات المياه بالخبر
شركة كشف تسربات المياه بالدمام
شركة كشف تسربات المياه بالقطيف
شركة كشف تسربات المياه بالاحساء
شركة كشف تسربات المياه بالهفوف
نجار بالرياض
فني نجار بالرياض
نجار شمال الرياض
شركة نقل اثاث من الرياض الي دبي
شركة نقل اثاث من الرياض الي الامارات
شركة نقل اثاث من الرياض الي الادرن
شركة تركيب اثاث ايكيا بالرياض
شركة تركيب غرف نوم بالرياض
مظلات
مظلات سيارات
تركيب مظلات
سواتر
تركيب سواتر
سواتر الرياض
برجولات
برجولات خشبية
تركيب جلسات برجولات
هناجر
تركيب هناجر
دهان القصيم
دهانات القصيم
دهانات جوتن القصيم
معلم جبس بورد القصيم
صباغ الدمام
تركيب ورق جدران بالقصيم
دهان الجزيره بريده
دهان جوتن بريده
دهان بريده
centercall502 wrote 06/06/2021 at 17:37 point
شركة نقل عفش بجدة
شركة نقل عفش بمكة
شركة نقل عفش بالجموم
شركة نقل عفش بالطائف
شركة نقل عفش بالخرمة
شركة نقل عفش ببحره
شركة نقل عفش بالليث
شركة نقل عفش بخليص
شركة نقل عفش بالقنفذه
شركة نقل عفش بتربه
شركة نقل عفش برابغ
شركة نقل عفش بابها
شركة نقل عفش بنجران
شركة نقل عفش بجيزان
شركة نقل عفش بخميس مشيط
شركة نقل عفش بالباحة
شركة نقل عفش بالمدينة المنوره
شركة نقل عفش بينبع
شركة نقل عفش بتبوك
شركة نقل عفش بعرعر
شركة نقل عفش بالرياض
شركة نقل عفش بحائل
شركة نقل عفش بالخرج
شركة نقل عفش بالقصيم
شركة نقل عفش ببريدة
شركة نقل عفش بعنيزة
شركة نقل عفش بالدوادمي
شركة نقل عفش بالخفجي
شركة نقل عفش بالخبر
شركة نقل عفش بالهفوف
شركة نقل عفش بالثقبة
شركة نقل عفش بظهران
دليل شركات نقل العفش
مظلات جدة
مظلات
مظلات الرياض
شركة عزل اسطح بجدة
شركة عزل فوم بجدة
شركة تعقيم منازل بجدة
شركات عزل الفوم بجدة
شركة مكيفات بالرياض
centercall502 wrote 06/06/2021 at 17:24 point
مكانك للخدمات المنزلية
نقل عفش بالدمام
شركة نقل عفش بالخبر
نقل عفش بالخبر
نقل عفش بالجبيل
نقل عفش بالقطيف
نقل عفش بالاحساء
نقل عفش بالهفوف
تنظيف منازل بالدمام
شركة تنظيف منازل بالخبر
تنظيف منازل بالخبر
مكافحة حشرات بالخبر
شركة مكافحة حمام بالدمام
مكافحة الحمام بالدمام
شركة مكافحة حمام بالخبر
مكافحة الحمام بالخبر
شركة مكافحة حمام بالجبيل
شركه مكافحه حمام بالجبيل
شركة مكافحة حمام بالاحساء
مكافحة الحمام بالاحساء
شركة مكافحة حمام بالقطيف
مكافحة الحمام بالقطيف
شركة تنسيق حدائق بالدمام
افضل شركة تنسيق حدائق بالدمام
شركة تنسيق حدائق بالخبر
افضل شركة تنسيق حدائق بالخبر
شركة تنسيق حدائق بالجبيل
تنسيق حدائق بالجبيل
شركة تنسيق حدائق بالاحساء
شركة تنسيق حدائق بالقطيف
ارخص شركة تنسيق حدائق بالقطيف
centercall502 wrote 06/06/2021 at 17:20 point
centercall502 wrote 06/06/2021 at 17:17 point
هوم سيرفر للخدمات المنزلية
شركة نقل عفش بجدة
شركة نقل عفش بحره
شركة نقل برابغ
شركة نقل عفش بمكة
شركة نقل عفش بالحوية
شركة نقل عفش بخليص
شركة نقل عفش بالمدينة المنورة
شركة نقل عفش بتبوك
شركة نقل عفش بينبع
شركة نقل عفش بالخبر
شركة نقل عفش بالخرج
شركة نقل عفش ببريده
شركة نقل عفش بحائل
شركة نقل عفش بابها
شركة نقل عفش بنجران
شركة نقل عفش بجازان
معلم دهانات بجدة
شركة تخزين اثاث بجدة
معلم دهان اخشاب بجدة
شركة تركيب طارد حمام بجدة
شركة عزل اسطح بجدة
شركة عزل فوم بجدة
شركة جلي رخام بجدة
كهربائي منازل بجدة
شركة تركيب كاميرات مراقبة بجدة
معلم شبابيك المونيوم بجدة
مظلات جدة
فني تركيب مطابخ بجدة
شركة مصاعد بجدة
سواتر بجدة
شركة ترميم منازل بجدة
شركة تنسيق حدائق بجدة
شركة صيانة مكيفات بجدة
