Ambient light sensor
07/17/2023 at 12:43 • 0 commentsThere is one spare Pico ADC, so why not add a further sensor such as a SFH 300 phototransistor for measuring the ambient light.
Cast resin
05/12/2023 at 07:15 • 0 commentsA rather lackluster attempt to create a protecting layer with cast resin for the PCB bottom side.
SD card
10/09/2022 at 06:15 • 0 commentsSD card can be added for storing measurement data. MicroPython code (example and necessary module):
Raspberry-Pi/sdcard.py at main · Florian-Wilhelm/Raspberry-Pi (github.com)
IoT capabilities
06/28/2022 at 11:17 • 0 commentsImplemented IoT capabilities (via ESP8266), i.e. value(s) can be fetched thru a web-browser.
Wiring ESP8266 - Pico:
Pin 1: GND
Pin 2 (TXO): Pico GP5 (UART1 RX)
Pin 4: 3.3V
Pin 7 (RXI): Pico GP4 (UART1 TX)
Pin 8: 3.3V
Other pins n.c. -
Improved Maths
11/17/2021 at 05:44 • 0 commentsImproved Maths for the capacitive sensor HW-390: the entire 00-99 range on the 7-Segment-Displays will now be used.
Background: Capacitive sensor HW-390 delivers around 3.0V (here: approximately 65.535 after ADC conversion and expansion) output voltage when the soil is completely dry, and 1.0V (here: approximately 21.845 after ADC conversion and expansion) when the soil is completely wet.
(Source of this schematic: Sensors | Free Full-Text | Characterization of Low-Cost Capacitive Soil Moisture Sensors for IoT Networks (mdpi.com) )
